PR- too much verb!
Discussion in 'Shock Brother's DIY Amps' started by Uncle Daddy, May 11, 2021.
  1. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    My latest PR build has way more reverb than is useful, and I'd like to try to throttle it back somewhat. I've got a 100k log pot on the way to alter the sweep, but I'm thinking that upping the 470k return resistor to say, 1M will give me what I'm looking for.
    Any pros or cons?
  2. hamerfan
    hamerfan Tele-Meister
    Germany, Bavaria
    Try a 12au7 tube.
    Nickfl, ArcticWhite and Paul G. like this.
  3. Jowes_84
    Jowes_84 Tele-Meister
    Kraut-Island, Chiemsee
    You can go up to 1,5meg (which is actually what one of the reissues has, I guess the 68 custom) and even reduce the pot to a 50k if it’s still too much.
    EDIT: it’s the 68 DRRI That has the 1.5meg - not the PRRI
  4. Uncle Daddy
    Maldon, England
    So I tried the 1M and it works well. It was way too splashy before, with almost no control over the sweep. Now it works much better, with the abbey sound at the end of the dial rather than in the middle. The decay is a little long, but I'll leave things as they are for now.
  5. tele_savales
    tele_savales Tele-Afflicted Platinum Supporter
    Brooklyn, Joey!
    A dwell pot can be pretty useful.
    djbDJB and JohnnyCrash like this.
  6. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    Did you try the 12AU7 tube?
    It gives way more control on the reverb dial. Before I swapped mine, the reverb was max surf at 3 and just about useless above that.
    With the 12AU7, you get a much more usable range.
    zook likes this.
  7. Jowes_84
    Yes but I prefer having the AT7 in there. I don’t own a PR(RI) but messed around with similar Fender circuits and found a bigger reverb mix helps. Plus some of the reissues use it too (I think 68 customs)
  8. 5F6Animal
    5F6Animal Tele-Meister
    Beaumont CA
  9. King Fan
    Salt Lake City
    So can I ask what it is you like better about the AT7? Nothing against changing the resistor, just curious.
  10. Jowes_84
    there are always pros and cons
    pro AU7
    it is easy and non-invasive
    does the job
    pro 1meg R
    I can leave the AT7 in that circuit where it was meant to be and for which the cathode resistor was chosen
    does the job
    the latter makes more sense to me but an AU7 probably also works... if I ever get to have a PR(RI) I will try that first
    my experimentation was mainly with later SF Twin Reverb and Rivera-Circuits
    King Fan likes this.
  11. Jowes_84
    plus - I might be wrong ;)
  12. zook
    zook Friend of Leo's
    Cochise, AZ
    Change the reverb driver grid leak resistor from 1 Meg to 470K,
