PR build troubles, any Ideas?
Discussion in 'Shock Brother's DIY Amps' started by Mark the Moose, Jan 3, 2020.
  1. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    Building the Weber 6a14hp, a 6l6 Princeton Reverb. All tubes have a nice glow, no red plating. No sound, low B+.
    B+1 is 262, B+2 is 258 and B+3 is 230.
    All voltage measure measurements at V1 also seem to be about 2/3 what they ought to be.
    My only guess is that I used the wrong PT lead to the AC input. It has a 120v input and a 125 v input. I used the 125 thinking that would be safer and only make a tiny difference on the back end. Could that be it?
    the OT leads to the 6l6 tubes are both 262v as well.
    ideas?
  2. FenderLover
    Minnesota
    I wouldn't worry about the input AC leads just yet. You don't have sound, so there is something different going on for sure and it could be literally anything. Can you post the plate and cathode voltages of the tubes, and show a few pics of the wiring, particularly the output stage? Is your bias set?
    Mark the Moose and Snfoilhat like this.
  3. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    Double check the ground connection on your cap can.
  4. corliss1
    Lansing, MI
    AC voltages right at the recitifier may be helpful here as well, since everything is low across the board.
  5. Mark the Moose
    Erie, CO
    Double checked everything at the cap can and I went ahead and changed the PT feed from 125v to 120v. Here are my voltage measurements:
    B+1 279v
    B+2 273v
    B+3 244v
    B+4 180v
    Everything seems to come in around 2/3 what I expect to see according to the layout below.
    If I'm measuring correctly, the red wires from the PT to the rectifier are reading:
    Rectifier pin 4 332v AC & 6 60v AC.
    (I measured the red probe on the wire and the black probe on the neutral AC wire, let me know if that should be done differently.)
    V6
    3 279v
    4 275v
    V5
    3 279v
    4 275v
    V4
    1 171v
    3 1.49v
    6 142v
    8 38v
    V3
    1 125v
    3 .82v
    6 125v
    8 .86v
    V2
    1 272v
    3 5v
    8 5v
    V1
    1 129v
    3 .76v
    6 123v
    Here is RobRob's signal flow layout with voltages.
  6. Mark the Moose
    Erie, CO
    The low measurement at the rectifier pin 6 makes me question whether the PT is bad. Is there a way to test the PT?
  7. corliss1
    Lansing, MI
    If the amp is grounded in a standard American outlet, measure with black on ground, not neutral.
    Yes, those numbers seem odd and could indicate a bad PT, but test again with black on ground and let us know.
  8. schmee
    No sound at all?
    Double check all the wiring. I have this trouble almost every time I start up a build. One thing either wrong or a wire missing. Especially those under board wires.
    Don't worry about voltages being off 20% or so for now.
  9. Mark the Moose
    Erie, CO
    Then I get 213v and 172v.
  10. corliss1
    Lansing, MI
    Alrighty, let's do this.
    Pull the rectifier tube.
    Measure the AC of the red wires right on the rectifier socket. What do you get there? Is that your 213 and 172?
  11. Mark the Moose
    Erie, CO
    Should I start with all of the tubes pulled, or just pull the rectifier?
  12. corliss1
    Lansing, MI
    We only care about what's coming out of the transformer at this point, so we just need the rectifier pulled for this test, although pulling more won't hurt anything.
    Could you also let us know the specific power transformer you're using?
  13. Mark the Moose
    Erie, CO
    With the rectifier pulled I get 419v and 320v.
    Tranny is:
    Weber W025130:
  14. corliss1
    Lansing, MI
    Seems odd - got some pictures of the wiring around the rectifier tube socket? According to that diagram I'd like to see somewhere around 340V on each red wire.
    Is the red/yel wire grounded?
  15. Mark the Moose
    Erie, CO
    That question causes me to wonder if I misread the layout...
    I used the "optional resistors" and taped off both the green/yellow AND the red/yellow. But looking again I think perhaps the red/yellow needs to be grounded in either case.
  16. corliss1
    Lansing, MI
    If you have the option, always go with the real center tap instead of the resistors. I'd remove the resistors and ground the green/yel and red/yel wires. Then see where you're at :D
  17. Junior Little
    Junior Little Tele-Meister
    Rural Illinois
    Yep, I'm with @corliss1 on this one:
    ground that red/yellow wire.
  18. Mark the Moose
    Erie, CO
    Boom! That was it. Dead quiet and sounds awesome! Thanks so much for your help, if you find yourself in CO I owe you a cold one.
    BigDaddy23, Paul-T and jsnwhite619 like this.
  19. mjcyates
    mjcyates Tele-Meister
    Louisville, KY
    Another "Happily Ever After"! Glad you got it figured out.
  20. corliss1
    Lansing, MI
    Yay!
