Power Transformer Testing Question
Discussion in 'Shock Brother's DIY Amps' started by ArcticWhite, Jun 13, 2021.
  1. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    I just tested this PT pulled out of a Hammond S6 Chord Organ.
    The red HT wires yield 780 VAC between them, with no load applied.
    Does that mean this is a 390-0-390 transformer?
    Yeah, this is a dumb question, but I just spent an hour searching Google, and I'm still just as dumb.
  2. Lowerleftcoast
    california
    If there is no load on the PT the voltage will read higher. Conventional wisdom is: the rated voltage is *as stated* when there is a load of X amps.
    If there is a HT center tap then a 780VAC (CT) can be denoted as 390-0-390.
  3. dogmeat
    dogmeat Friend of Leo's
    Alaska
    yeah if there is a center tap
  4. ArcticWhite
    Portland Oregon
    Yes, there is a CT.
    Thanks guys.
  5. ok_state_blues
    ok_state_blues TDPRI Member
    I have a similar pt that I just got no long ago and got the same measurements. What's your plan for you pt? Just curious if you have a certain circuit in mind or will try to drop the voltage to make it compatible with another.
  6. ArcticWhite
    Portland Oregon
    Planning to sell it.
    It's too heavy and large to use in a 15 watt amp, which is big enough for me.
    ok_state_blues likes this.
  7. gusfinley
    gusfinley Tele-Afflicted
    SLC, UT
    If you have a schematic you might be able to back out the primary voltage based on the rectified DC output.
