Power transformer readings
Discussion in 'Shock Brother's DIY Amps' started by Jewellworks, Sep 20, 2020.
  1. Jewellworks
    Jewellworks Tele-Meister
    Orlando
    ive got this power transformer that came out of an old Ampro Projector that was running 3, 6V6's, 5Z4, 6SJ7, 6J5 and something else... i planned on using it for my "Vintage Build" and i just got around to finding out whether its dead or not. turns out its not. so yay. but i wanted to post the readings i was getting from it, un-installed, and just sitting on my workbench. -to see if anything jumps out as abnormal, or is it good to go?
    OHM READINGS:
    primary: 5.9ohms
    2ndary:
    HT: 217.4
    HT-a to C/T: 103
    HT-b to C/T: 114.6
    6.3v Filament: .03
    F-a to C/T: .02
    F-b to C/T: .04
    5v Heater: .03
    VOLTAGES: using a variac, i set the input to the primary at 120VAC
    2ndary: HT: 862 VAC (!!)
    HT-a to C/T: 432
    HT-b to C/T: 429
    6.3v Filament: 7.53
    F-a to C/T: 3.77
    F-b to C/T: 3.73
    5v Heater: 5.77
    im concerned about what looks like an enormous voltage on the HT 2ndary, and it being un-even on either side of the C/T by just a few volts. i can always knock the voltage back with some big resistors, but im sure the un-even-ness will this balance out with the filter caps.
    the 6.3v filament seems high, but theres no load. can i add a Humdinger to balance the load? with a C/T filament? ive seen posts with people talking about "elevated filaments" but i dont really know how that works, or for what purpose.
    im thinking its good overall, but probably way more than what i need for my Vintage build. but its what i have on hand, so there you go.
    thoughts?
