Power Transformer mechanical buzz/hum
Discussion in 'Shock Brother's DIY Amps' started by Linkjr, May 4, 2019.
  1. Linkjr
    Linkjr Tele-Meister
    Uk
    Hi Guys,
    My champ was playing perfectly then got an intermittent hum/ buzz which I initially thought was a ground hum, I have checked all components including the back of the board but can't find anything suspect.
    I removed the chassis and narrowed it down to a mechanical buzz hum from the power transformer which is intermittent.
    Is this indicative of a problem in the circuit or a type of transformer failure?
  2. Greg_L
    Greg_L Tele-Holic
    Have you tried tightening the mounting and lamination bolts?
    Linkjr, FrontPU and Wally like this.
  3. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Some PT's do hum when in use. I had a Marshall DSL 50 that had a noisy PT and it ran fine for many years. I do agree with Greg L though, check all mounting and lamination bolts first. Also take a close look at the power tube. A bad tube will draw excessive current and cause the amp to hum loudly.
    FrontPU, Chiogtr4x and Wally like this.
  4. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Is this a vintage transformer or? Just curious how old it is.
    telemnemonics likes this.
  5. schmee
    Rectifier maybe....
  6. Wally
    +1 on checking the nuts, bolts and screws. I have been around vibrating PT’s that exhibited no other issues, but Inhave never seen one that had an intermittent problem.
  7. Bob Womack
    Bob Womack Tele-Afflicted
    Between Clever and Stupid
    I've got an Avalon VT-737 tube preamp in the turret rack to my left in the studio that has physical power transformer hum that comes and goes. There's a multi-rack distribution amp rack behind me that has the same problem. In rack units it is often amplified by the business of directly bolting the rack units to your studio rack. I've put in rubber or paper shims to mitigate the noise. My Marshall amp has worked fine since I bought it new in 1996 though it has physical power transformer hum.
    Tranny crap happens. :D
    Bob
  8. Linkjr
    Linkjr Tele-Meister
    Uk
    Thanks for the response guys, I have tightened all the bolts on the PT, have the chassis out and doing some more testing, it's fairly new less than 2 years old , I saw an arc on pin 8 of the 5y3 but happened after the intermittent buzzing started I resoldered and changed the tube but buzzing is still intermittent
    It's strange the amp still works as it did before but the buzzing with tha amp out of the chassis is really loud
  9. Greg_L
    Greg_L Tele-Holic
    With the amp guts exposed it's subject to all kinds of interference. It's not unusual for an amp to buzz and be noisy when it's out of it's cabinet.
  10. Linkjr
    Linkjr Tele-Meister
    Uk
    True Greg_L but this is a recent thing my amp was previously dead quiet, even chassis out. In troubleshooting I turned off when I heard no buzz then turned back on and had it buzz - not switching or changing anything in the environment.
  11. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Voltages are the same with and without the buzzing?
  12. Linkjr
    Linkjr Tele-Meister
    Uk
    Just an update the intermittent issue is now permanent :(
  13. Greg_L
    Greg_L Tele-Holic
    In a way, that's good. A consistent problem is easier to track down than an intermittent problem.
  14. Linkjr
    Linkjr Tele-Meister
    Uk
    Yes that's the best way to look at it, every cloud etc
    Ok! I made some progress I got rid of the buzz by switching off my cathode bypass cap on switch, the problem is the volume seems to be abnormally low with this off now.
  15. Chiogtr4x
    Manassas Park, VA
    Related topic /questions, please
    ( BTW , I'm a good player but NOT a tech-type, but still try to learn, if I can ever really retain any info! )
    I just took my 1999 Blues Jr. ( which I really have used for a thousand gigs, I bet) to my amp tech buddy, as it had literally died right before a big show( light ON, tubes glowing, NO sound)
    He always does initial trouble shooting with customer there ( me!) for 15-20 min., then I leave amp for about a week, turnaround time.
    tThis time after checking ( with multimeter and scope, he also tested tubes) he determined that the power Transformer died- not common in BJ's he said, but my amp has a lot of use...
    Anyway, can someone ( in simple terms) explain how a PT works/ what it doe, and what 'stops happening' that makes one go bad? Just curious...
    Thanks!
  16. Obelisk
    Obelisk Tele-Afflicted
    NW USA
    I had a 67 Traynor YBA-1 that had a power transformer that would audibly hum if the amp volume was turned down. Once I was playing, I never noticed the sound. I was told a by a tech that the sound is caused by the hardening of the epoxy that holds the laminations together. It wasn't totally annoying, but it was an audible hum that had nothing to do with anything wrong in the circuit or the tubes. These were the older Canadian made Hammond transformers. I still own 4 other Traynor amps that do not exhibit the same phenomena. I have also had a Gibson GA-79 that had a similar problem.
  17. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Sure I'll start. A transformer is a long piece of wire wrapped around a core.
    Some ways a wire can stop working as intended: 1) it breaks, 2) it touches something it shouldn't
    Maybe I oversimplified it, I dunno. :)
    Chiogtr4x likes this.
  18. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Interesting discovery!
    The lower gain without the bypass cap is expected, a cathode bypass cap by nature increases the gain of the stage it's associated with.
    By the way, a parasitic oscillation can cause a transformer to vibrate like crazy. I wonder if it's possible there's an oscillation happening that you can't hear? This is why I asked about the voltage earlier btw, an oscillation would lay into the power supply causing it to sag.
  19. Linkjr
    Linkjr Tele-Meister
    Uk
    Thanks Sds1, Unfortunately after powering off and on the buzz is back, I also took my switch out of the equation and setup as stock no bypass cap, low output and mechanical buzz.
  20. Linkjr
    Linkjr Tele-Meister
    Uk
    So need to take some measurements
    my b+ was around the 340 - 350 range last time I needed to measure it and was definitely not buzzing at the time.
