Power transformer getting too hot,low plate voltage
Discussion in 'Amp Tech Center' started by J-Turn, Mar 25, 2020.
  1. D'tar
    D'tar Friend of Leo's
    WNY
    1N4007 would work.... Buy them by the dozen or two.
    Do you have any diodes at all? There are lots of options
    Wally likes this.
  2. J-Turn
    J-Turn TDPRI Member
    Indiana
    I do, I’ll look for them
  3. J-Turn
    J-Turn TDPRI Member
    Indiana
    Put in some new 1N4007’s
    +39 and -21mv (bouncing up to -30mv)
    Wally likes this.
  4. D'tar
    WNY
    Did you check that secondary winding for output on both halves of the 25-0-25 coils. What is vac on either side and across both outer legs? You would check this just like you did the HT winding earlier. On the center tap of that winding... What is the resistance reading to ground/chassis. If you have less than say 140r(r702) which i believe you will find, you have a short to ground.
    Just in case... Where are your probes connected while checking voltage? black to chassis and red to each test point?
    Wally and Snfoilhat like this.
  5. J-Turn
    J-Turn TDPRI Member
    Indiana
    With all tubes in
    Rectifier pin1 269ac
    Pin7 269ac
    Pin1-7 536ac
    Pin1 to ground 209ohm
    Pin7 to ground 197ohm
  6. J-Turn
    J-Turn TDPRI Member
    Indiana
    Yes black to chassis and red to test point
  7. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Never rely on a meter to tell you that an old capacitor is good or bad. It may read correctly with 9v from your meter, but in a circuit with several hundred volts it could read and perform much differently. Not suggesting that they are the cause of the problem though. Keep following the advice of the fellas above.
    J-Turn and Wally like this.
  8. Wally
    “With all tubes in
    Pin7 269ac
    Pin1-7 536ac
    Pin7 to ground 197ohm”
    J-Turn, aren’t these measurements taken on the HT secndary winding to the rectifier? D’Tar was suggesting that you measure the
    25-0-25 secondary that is feeding SD701 & SD702 to provide the bias voltage.
  9. J-Turn
    J-Turn TDPRI Member
    Indiana
    Maybe I’m barking up the wrong tree, but the voltage going out of the plastic connector to the organ(schematic)goes through the tone generator etc. and feeds back in to MY power amp via the yellow wire That feeds directly into the negative side of C712 which goes directly to Pin8 of the 12at7.
    The voltage is too high what would be sent out to the Organ, and now is too low what is being sent back from the Organ.
  10. elpico
    elpico Tele-Afflicted
    Vancouver BC
    The 25V-0-25V winding is the B+ supply for every solid state device in the organ. Do you have all those tone generator boards running? If they're not drawing current then no voltage is developed across R702, so no negative bias voltage is available for the EL84 tubes. (which frankly is kind of a dumb design)
    Some options to make it work without the mountain of obsolete solid state boards:
    - add a second 140ohm 5watt resistor to balance R702. You'd connect this from the positive end of C702 to ground. (1 new part)
    - get rid of this bias circuit altogether and convert it to cathode bias. (2 new parts)
    - get rid of this bias circuit altogether and build a better negative bias supply off of the 25-0-25 winding. (several new parts)
    side note: don't turn it on with the power tubes in again until you deal with the bias voltage.
    Snfoilhat, D'tar, Wally and 1 other person like this.
  11. J-Turn
    J-Turn TDPRI Member
    Indiana
    Thanks for the input! I don’t have anything belonging to the Organ outside of the power amp unit in my pics.
  12. J-Turn
    J-Turn TDPRI Member
    Indiana
    I added a 139ohm resistor and here are my new measurements:
    El84 (1) pin9 347v. Pin7 350v
    El84 (2) pin9 347v. Pin7 447v
    6ca4 pin3 355v
    12at7 pin1 237v pin3 109v pin6 325v pin8 (bouncing maybe 25v)
    12ax7 pin1 193v pin6 162v
    Should I add a little more resistance to bring those numbers down slightly to schematic, or is this close enough to not harm anything? PT is now running cool
  13. D'tar
    WNY
    Yep, I was thinking of this on the way home from work today.
    JT... what do you have for bias voltage on power tube pin 2
    Wally likes this.
  14. Wally
    +1 on wanting to know what that negative bias voltage on pins 2 in the EL84s is.
  15. J-Turn
    J-Turn TDPRI Member
    Indiana
    -14.3v for both
    Wally, D'tar and Snfoilhat like this.
  16. elpico
    Vancouver BC
    Rocking. Next you'd check how many watts that -14.3 idles the el84 at. Then you get to stop measuring and have fun. Does the trem work? Sounds like your oscillator is running.
    Wally, D'tar and J-Turn like this.
  17. Wally
    Okay....now are you ready for the test that will be administered tomorrow focusing on this exercise.....what tube elements can you identify, what is bias voltage, etc???? (;^)
    What does the amp sound like? It will have lost some of that heat in the Sonics along with losing the heat from the excessive current, but it should be operating properly. next exercise would be learning how to measure the current draw and how to figure the plate dissipation. Do some research????
    Snfoilhat, J-Turn and D'tar like this.
  18. D'tar
    WNY
    Bravo Sir! I was assuming the rectified positive half of wave available after the diodes would have the negative half of the wave on the center tap. As you pointed out it was an incomplete circuit on the + side. Thank you
    Possibly able to do this with the components at hand with some creativity!?
    J-Turn likes this.
  19. D'tar
    WNY
    Ha! I bet it sounded pretty radical running wide open!!!!
    Surprised the el84s are still usable!!!
    Wally likes this.
  20. D'tar
    WNY
    Good job JT!!!
    J-Turn likes this.
