bigguy12321
Hello all.
Just finished a Champ style amp, point to point, and am experiencing something new to me.
The power trans hums a little. That wouldn't be too bad but it transfers through the speaker.
What follows is a list of what I've tried in no particular order.
Tightened P.T.
Two different P.T's.
One different O.T.
Different set of new filter caps.
Checked and re-soldered all grounds.
Pulled preamp tube to isolate.
Unhooked 22k to 12AX7 tube to isolate noise.
New tubes.
Unhooked filament/ lamp lines.
Unhooked H.T. lines.
New diodes.
Shielded O.T.
Moving O.T. farther from P.T.
Turning O.T.
Tried a few different outlets. Even one across town...
The amp works otherwise, just hums... noticeably.
I'd say bad P.T. as it hums under no load, but I've tried two others with exact same sound.
I basically rebuilt the amp a couple times and cannot get the sound to even change.
It's definitely the same hum from the P.T. just amplified.
I have built several of this style amp and this is the first time any trans hum has been amplified.
Thanks in advance for any tips or suggestions.
Aaron
Tightened P.T.
One different O.T.
New tubes.
New diodes.
Shielded O.T.
Turning O.T.
Aaron
