Power scaling mosfet
Discussion in 'Shock Brother's DIY Amps' started by rainywish, Dec 9, 2019.
  1. rainywish
    rainywish TDPRI Member
    Belgium
    Hi,
    I'm planning to do some experimentation with a variable voltage regulator in a cathode bias amp. Schematics I find online and commercial kits use a nte2973 mosfet. Unfortunately this one seems hard to find (in Europe at least). Mouser stopped selling them a few years ago. Are there any known alternatives?
  2. Guitarteach
    I used a Toshiba K2968 MOSFET but that was three years ago.
  3. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    I had a VVR in a Tweed deluxe. It didn't make the amp growl at a low volume, it just made it cleaner. I had better luck with the 1/4 power mod on Robrob's pages, only I swapped the resistors to make it one tenth power. It worked pretty well.
    Paul-T likes this.
  4. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Can you find STP20N90K5 or APT14F100B ?
    These components should meet the minimum specs of NTE2983. Price / availability may be better if you were to relax the specifications a bit. Specifically, I think the Vds could safely be < 900VDC...
  5. Bitsleftover
    Bitsleftover Tele-Meister
    Cheshire UK
    Tube-Town VoCo kit
    Paul-T likes this.
  6. Ten Over
    Ten Over Tele-Meister
    Central California
    There's nothing magic about the NTE2973 and I don't even think it's a very good choice for a VVR. I have used STW12NK90Z and STW15NK90Z multiple times with good results. I've got a couple of STW12NK90Z's going right now re-forming some capacitors upstairs. I like the internal gate-to-source zener protection.
    At first it seems like the specifications are overkill. The STW12NK90Z lists 900V and 11A. Holy cow! Yeah, well, it won't do 900V and 11A at the same time because it is also rated at 230W. And the wattage derates to the tune of 1.85W per degree above 25 degrees. What those big numbers are good for is to generate a Safe Operating Area graph so that you can be confident that you will be well within that area at the conditions you will be operating under.
    If this is your first foray into VVR, there are a couple of important things. These suckers get hot, so they need to be heat-sinked (usually to the chassis). Most of the devices have the drain connected to the thermal pad on the back, so a thermal-conductive insulator needs to be used so that you don'e short your HT to the grounded chassis.
