Potentiometer heat sink? ( for soldering, not because it gets hot )
Discussion in 'Tele-Technical' started by Wallaby, Jan 28, 2020.
  1. Wallaby
    Wallaby Tele-Meister Silver Supporter
    Midwest
    Does anyone ever use a heat-sink when soldering to the backs of potentiometers?
    I've never had a problem not doing it, but I got to wondering.
    If you do - how do you do it? Those little heat clips are too small to fit a pot case. Maybe a small vise grips with a ring of folded over aluminum foil around the case?
    Maybe this is a silly question, but I thought I'd ask.I think you'd have to go way, way too long on a pot to have a problem
  2. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    the pot IS a heat sink..... ha ha
    seriously, the trick is to use a really hot iron and get it tinned as quick as possible before too much hear soaks into the shell. can you damage it with an iron... maybe but I don't know for sure
  3. mkdaws32
    mkdaws32 Tele-Holic Silver Supporter
    Moncton, NB Canada
    Yes...yes you can ;). You are quite right. Use an iron that will get it hot quick and get out quick. Some cheaper post have plastic in them an it’s easy enough to fry them by applying heat too long. I don’t know if I have ever killed a CTS pot, but I suspect it’s possible. I did kill an Alpha pot once and they are decent pots. It just didn’t want to heat up fast - probably my iron was dirty.
  4. mkdaws32
    Moncton, NB Canada
    Other good suggestions are to scratch up the area on the back of the pot where you plan to solder and apply a little solder paste. That will help it heat up faster and adhere better.
    stepvan and W.L.Weller like this.
  5. rolandson
    rolandson Tele-Holic Silver Supporter
    Cascadia
    An alligator clip between where I want the hot, and where I don't want the hot.
    jfgesquire likes this.
  6. Jon Snell
    Jon Snell Tele-Meister
    Jurassic Coast. UK.
    If soldering at the correct temperature with the correct type of solder that has flux in it, there is no issue.
    To solder the case of a pot, at a bit temperature of 190℃ and a power of at least 45Watts, should take no longer than 10 to 12 seconds. That is not enough time to damage the pot.
    stepvan likes this.
  7. radiocaster
    europe
    I don't see the point for the back of the pot, you want hot so it can stick.
    I do use a heat sink when soldering the legs. I used to not to, and damaged several Alpha pots by not using a heat sink.
  8. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    I soldered for a living years ago and had only ruined one pot the whole time. It was an inexpensive/cheap pot on an Epiphone guitar. I've never used any kind of a heat sink.
    I use an iron running at 800 degrees F, and it only takes about 2 to 3 seconds max.
    telestratosonic, moosie and dogmeat like this.
  9. Telecentric
    Telecentric Tele-Meister
    Boulder Creek, Ca
    As noted above, a heat sink would make soldering to a pot case harder, not easier. My alternative is to use solder ring terminals around the shaft and not solder to the case at all.
    mkdaws32, dogmeat and archtop_fjk like this.
  10. archtop_fjk
    archtop_fjk Tele-Holic
    Lebanon, NH
    I've always found the whole exercise of soldering wires to the backs of pots to be a real pain. I always end up with too much solder and wire bundles that are hard to position right (and then get crammed into a small cavity in the guitar). I cross my fingers that nothing is touching the ground connections incorrectly once I've screwed the control plate down, otherwise I have to get out the electrical tape to insulate everything.
    Why doesn't someone come out with a potentiometer specially made for guitar wiring which has a built-in lug/terminal on the back for soldering the grounds?
    telestratosonic likes this.
  11. stepvan
    stepvan Tele-Meister Silver Supporter
    amherst
    I have a 40w iron and never had an issue as well. The key is wattage
  12. memorex
    memorex Friend of Leo's
    Chicago
    Washer with a solder lug. I use them all the time to avoid having to solder to the pot case.
  13. Telecentric
    Boulder Creek, Ca
    Yes, the absolute best way to create a cold solder joint is a large puddle of molten solder with a number of not quite still wires in it as it cools.
    As noted above, there is a very cheap, perfect solution.
    https://www.allparts.com/products/ep-4968-solder-lug-washers
  14. dan40
    dan40 Tele-Afflicted
    Richmond Va
    In guitars that require soldering several wires to the back of the pot, I will solder a small loop of 18-22awg buss wire to the pot. I will then wrap and solder all grounds to the buss wire. This way I only have a single soldering point on the back of the pot. On Strat type guitars, I will solder a straight buss wire across all three pots and then attach all grounds somewhere along the buss wire. Much easier to remove and reattach the grounds from the buss wire if future maintenance or part swapping is needed.
    eallen and jfgesquire like this.
  15. sudogeek
    sudogeek Tele-Meister
    Palm Beach FL
    Memorex and Telecentric beat me to it. There’s really no call for soldering to pots. I’ve never damaged one but replacing a pot when there’s a bunch of wires on it or a bus soldered across several pots is a pain. Plus, those junctions are always suspicious.
    I stopped doing that several years ago. There are several sources of 3/8” washers with crimp connector (which I prefer) or solder lug. Here’s another type from Digikey:
    https://www.digikey.ca/product-deta...-amp-connectors/2-34115-2/A27018CT-ND/2233395
    These work fine and are much easier to deal with for repairs or further modding.
    telestratosonic and Telecentric like this.
  16. moosie
    Western Connecticut
    A 40W iron takes too long on the pot, for my taste. 800-900F, on and off in three seconds. Never had a problem, and unlike using a 40W stick, the solder is all round and smooth, not tortured-looking.
  17. Wallaby
    Midwest
    Thinking out loud, I wonder how well using the washers with solder lugs would work with an ES-335 or its brethren?
    It seems like the pots might get separated from their washers while fishing the harness into place.
  18. mkdaws32
    Moncton, NB Canada
    Yep - use these a lot.
  19. sudogeek
    Palm Beach FL
    I rewired a Sheraton most recently and it’s not a problem. You use the same technique as placing the toothed washer. You tie twine or fishing line to the shaft of the pot, then thread line through the washer+lug, then thread the line through the toothed washer. I use an angled surgical clamp to get the line through the appropriate hole. Pull the pot in place and, with a little fiddling, direct the shaft through the hole. The washers slide into place. Pretty straight forward and no more fiddly than having all these wires and grounds trailing after the pot if you use that as a solder point.
  20. jfgesquire
    jfgesquire Tele-Holic
    Lake View
    Something similar here. Tinned copper wire, from craft store, identical gauge to what you see in Gibsons. Then solder pickup ground wires to it.
    Some things still get soldered to pot for economy of space, but it's a lot less and a lot cleaner and more organized this way.[​IMG]
    Sent from my LG-H932 using Tapatalk
    dan40 likes this.
