Pot short?
Discussion in 'Tele-Technical' started by bluetele54, Apr 15, 2021.
  1. bluetele54
    bluetele54 Friend of Leo's
    SF Bay Area
    Tele fell...
    Bridge pup weak, out of phase sounding.
    It’s a rewind, but one done over 22 years ago.
    Is it possible that either the tone control or vol. may have been hit and created the issue?
    Thoughts?
    Boreas likes this.
  2. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Many possibilities. Check the switch. It may have been bent out of position. See if is sounds better in in-between settings. Also could have knocked a solder joint loose. You've got some 'vestigatin' to do.
  3. bluetele54
    SF Bay Area
    I’m thinking solder joint as well.
    Yes, tried different switch positions, but to tour point, it may be bent out of position.
    It’s a drag, as the guitar is arguably my best sounding one over all, or one I’ve become very comfortable with over time.
    It’s an original ‘52 body with an original Nocaster neck.
    A glorified parts guitar, but a good one.
    Boreas likes this.
  4. Boreas
    Not something you want to throw on the scrap heap yet!
    The switch sticks up pretty high and can get jammed pretty easily in a face plant. This will mess with the alignment of the contacts. Fairly fragile. Shouldn't hurt the pots much, but a cold solder joint can fail anywhere.
  5. bluetele54
    SF Bay Area
    That’s my thought too re solder joint.
    I’ll check the switch again though.
    I’ve never heard of a pup failing from a fall.
  6. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Pickups, when they're mounted in a guitar, are fairly robust. By themselves, however...if you drop one on the floor it can kill it.
    Do you have a DMM? If so, check each component for proper operation, and desolder one of the pickup leads and test the pickup for proper Ohms resistance spec.
    If you don't have a DMM, you're in luck because they are inexpensive. Even the cheepies do everything you need to test a guitar circuit. Some don't have a capacitance setting so make sure to get a meter that included that function.
