Possible grounding problem
Discussion in 'Tele-Technical' started by 1955, Feb 15, 2014.
  1. 1955
    1955 Doctor of Teleocity
    I'm getting shocked at the mic, and I posted a thread in the amp central station, as I haven't located the culprit.
    It occurred to me that I haven't considered my guitar in the equation, since I'm not experiencing the normal symptoms of a bridge grounding problem.
    But I thought I would ask the much more knowledgeable folks here just in case, if it is possible to have a problem with the grounding (mine is run under the bridge plate, Ted Greene/Parka style wiring, single coils,) and yet still have the normal functioning (quieter when touching bridge/strings, etc.)
    Thankful for any help!
  2. Jimmy Jazz
    Jimmy Jazz TDPRI Member
    Christchurch, New Zealand
    The best I can do is "bump" this for you!
  3. Outcaster
    Outcaster Tele-Holic
    The Mountains of Western North Carolina
  4. Keyser Soze
    Keyser Soze Tele-Holic
    Johnson City, TN
    Sounds like you have a polarity problem with the power sources for your amp and the PA.
    Does your amp have a three prong cord?
    How about the PA, or whatever the mike is plugged into?
    Get a circuit tester from the hardware store and use it everywhere you play.
    Do not plug into anything that does not test out as having a good earth ground connection, and then run everything off of that source, or other verified sources.
    Just because it is a three prong outlet it does not mean that it has an actual earth bond, nor does it guarantee that hot is hot and neutral is neutral.
    When one amp (e.g. guitar) is wired hot and the other (e.g. microphone) is wired neutral the current tries run between them using your lips, fingers and everything in between as the conduit. The 'in between stuff' includes your heart. Hearts do not like extraneous voltage sources, it makes them do funny things, like stop beating.
    This is exactly what killed Keith Relf.
  5. 1955
    Thanks for all the help, been using the outlet tester at gigs, but it may likely be the PA. Have swapped around stuff, including my main surge protector that everything plugs into (amp, PA, etc.), but have not swapped the extension cord running off the PA to my main surge protector, that could be the problem. The amp is 3-prong, but its been dropped a couple times, am troubleshooting it right now in amp central station.
  6. 1955
    Update: issue solved, my amp was the culprit. And my butt looked big in my jeans. It's an ongoing struggle. Thanks for the help everyone!
