Pop sound and then a fizzy buzz sound on certain notes.
Discussion in 'Glowing Bottle Tube Amp Forum' started by gobi_grey, Jan 14, 2020.
  1. gobi_grey
    gobi_grey Tele-Afflicted
    clinton, ia
    Monoprice 5 watt, playing pretty much wide open and there was a pop sound(not real loud) and now there is a fizzy buzz type sound when hitting notes at louder volumes. It happens at the attack of the note, buzzes for a second and then stops. Sounds like a blown speaker. Still happens with other speakers.
  2. Wally
    Bad tube is likely. Bad solder connection possibly. Sub some tubes in one at a time to eliminate that possibility. If that doesn’t cure the problem, it is tech time inside the amp.
    JayFreddy and rangercaster like this.
  3. MuddyWolf
    MuddyWolf Tele-Meister
    Paradise, Ca
    I have the MP15 and like it alot. BUT... I think its questionable to be cranking the amp on ten. Even well made amps will eventually fail if pushed to the max. El cheapo chinese tube amps will fail even sooner. Yeah it sounds good. That's the death moan of tortured electronics.
  4. gobi_grey
    clinton, ia
    Yeah it was a tube. I probably should have checked that before posting but I figured it was the Chinese amp and not the good ol' american tubes. The only American made thing in the whole amp. Haha.
    rangercaster likes this.
  5. Wally
    NOS? UOS with unknown usage?
  6. gobi_grey
    clinton, ia
    Uos, had them in and out of different amps, always worked fine. Figured they were good. Just glad the amp is working. It sounds great through a 10" wgs in my old radio cab.
    Wally likes this.
  7. Wally
    Everything has a lifespan, ime. UOS means that one never knows where the tubes have been or what they are been subjected to.
    muscmp likes this.
  8. gobi_grey
    clinton, ia
    True. I think those actually came from a big box of tubes I picked up at a yard sale last year. Got it for just a few dollars. Quite a few grey glass 6v6 and a bunch of 12ax/u/y7's. Pretty neat score.
    Wally likes this.
  9. soundchaser59
    soundchaser59 Tele-Holic
    Up The Creek
    A scorched grid resistor will do that same thing to an amp.
  10. muchxs
    muchxs Doctor of Teleocity
    New England
    I build my stuff to run wide open 24/7.
    Ya just gotta know what runs hot and make it run cool. Beef up what usually blows up.
    For example the bias resistor in a stock Champ is usually a 2 watt carbon comp. The one I just built has a 10 watt ceramic type.
    jtcnj and Wally like this.
