Poll: How Many of You Shim Your Tele Necks?
Discussion in 'Tele-Technical' started by El Tele Lobo, Feb 2, 2020.
Do you shim your neck?
  1. Shim-shimminy shim-shimmy shim-shim shim me!
    23 vote(s)
    12.1%
  2. No shims here...blasphemous!
    31 vote(s)
    16.3%
  3. What's a shim?
    10 vote(s)
    5.3%
  4. I thought this was the 3 Stooges thread...
    2 vote(s)
    1.1%
  5. Only when necessary
    124 vote(s)
    65.3%
  1. El Tele Lobo
    El Tele Lobo Friend of Leo's Silver Supporter
    I've shimmed one of my tele necks on a build I did. It improved my string action immensely. I'm thinking of doing it to a couple other teles. How many of you have had to do this? Do you find you have to do it to most of your teles or only rarely? Don't forget to weigh in on the poll.
  2. BBill64
    BBill64 Tele-Afflicted
    United Kingdom
    you don't shim to adjust action, you shim to change the range of adjustment at the bridge, or to increase break angle over the saddles.
    i like to shim for the break angle and so i can raise the strings over the ashtray without having insanely high action.
  3. Old Deaf Roadie
    Old Deaf Roadie Tele-Afflicted Silver Supporter
    Oregon
    My preference is only when necessary. I suppose I could, in all practicality, add a shim whether I think I need one or not to preempt having to mess with the neck once it's where I like it, but that is a risk I am willing to take as I am quite particular and opinionated about what constitutes a proper neck joint/fit/pocket (which I will keep to myself here because it all works for me & I'm not up for an argument, but will note it involves maximum surface area contact and no air gaps). I am curious to see what others, particularly the professional builders have to offer on the subject.
    jdw3, kirby02, gitold and 1 other person like this.
  4. jackal
    jackal Friend of Leo's Gold Supporter
    mojave desert
    I've only had one guitar that needed to be shimmed, I used the stew-mac shim so there would be no gaps.
    kirby02, mkdaws32 and Old Deaf Roadie like this.
  5. Vibrolux59
    Vibrolux59 Tele-Meister
    PNW
    Only if needed.
    kirby02 and DaveG_NJ like this.
  6. brookdalebill
    Austin, Tx
    Generally speaking, no.
    My Cabronita has a micro-tilt.
    I may have used it.
    kirby02 and El Tele Lobo like this.
  7. FenderGuy53
    FenderGuy53 Poster Extraordinaire
    Marion, NC
    Never had to... :rolleyes:
  8. Dan German
    Dan German Poster Extraordinaire Silver Supporter
    Left of the Left Coast
    “Only if necessary” seems like the sensible approach. If it’s not necessary, why do it? If it is necessary, what else are you going to do, throw the guitar away? (If yes to the latter, I will PM you my shipping address.)
  9. Rich_S
    Rich_S Friend of Leo's Silver Supporter
    Potsdam, NY
    Both my Teles have tapered shims. In both cases I needed more neck angle to get the action down, because the bridge saddles couldn’t go any lower.
    Especially in the case of my blue MIM Tele, cleaning the gloppy paint runs out of the neck pocket, flattening it’s bottom, adding a shim, and tightening the whole assembly down solidly turned a barely-playable turd into my #1. Huge benefits in both feel and tone, for zero dollars invested.
    “Only when necessary”. A shim isn’t good or bad in and of itself, but a valuable option in getting the whole neck pocket/bridge/truss rod setup correct.
  10. beagle
    beagle Friend of Leo's
    Yorkshire
    Not me Tele, but two of my Strats and my bass were shimmed when I first set them up to suit me..
  11. baiff
    baiff Tele-Holic
    FLOOR-AH-DUH
    I have never shimmed a parts tele but I also buy 3 barrel saddles with flat bottoms for better adjustment.
    El Tele Lobo likes this.
  12. moosie
    Western Connecticut
    Shimming should always be a last resort, after a full setup has been attempted, and the action or saddles can't be adjusted properly due to issues of travel.
    If the saddles are bottoming on the bridge before you get the action low enough, then shim the rear of the pocket.
    If the saddles are teetering high on their spindly legs, and you still have fret buzz, and you don't like the stiff feel of the sharp break angle behind the saddles... then shim the front of the pocket.
    Once you shim, you'll need to repeat the complete setup. Truss rod/relief, saddles/action, pickup heights, set intonation. The nut is the exception - it won't need re-addressing just because of a shim.
    Just like you don't use the truss rod to set action, but adjusting it affects the action... same is true of a shim. It's not the way to adjust the saddles, but shimming does bring the saddles back into their normal range of travel on the adjustment screws.
    kirby02, DaveG_NJ, KyAnne and 2 others like this.
  13. Chunkocaster
    In space with Ziggy
    I had to shim my last tele partscasters neck, first time I've needed to, I cut a small amount off the end of a old non stamped credit card and it fit perfectly.
    kirby02 and mkdaws32 like this.
  14. Tommyd55
    Tommyd55 Tele-Holic
    Southern Louisiana
    Out of my 3 guitars 2 are shimmed, my Pcaster tele is not. I use the StewMac tapered shims, usually a .25 or .5
    The guitar in my avatar , a Mex fender Jaguarillo, it made very pronounced difference in comfort and play-ability. Gave me much improved action with an increase in break angle over the Staytrem bridge, and made it able to dial in lower action on the neck with no buzz. Has helped turn it into a very stable guitar which it was not at all as it came from the factory 6 years ago.
    Skub, Kriticaster, kirby02 and 4 others like this.
  15. telemnemonics
    Seldom on a Tele but usually on a Strat and certainly on a Jazzmaster unless it has an angled pocket.
    I've never ever had to shim the open end of the pocket, only the heel.
    I've also never bought one of those expensive full length shims to eliminate air gaps.
    kirby02 and SnidelyWhiplash like this.
  16. moosie
    Western Connecticut
    Most actual Fender Strats and Teles won't need shims. Some weirdness in the level or flatness of heel or pocket may occasionally require it, but it's fairly unusual, in my experience. It may be more common with off-brands, like my Fender-licensed rosewood neck from WD Music. Looks perfect, but no matter which Fender body I bolt it to, it needs a shim.
    Fender offsets are another story. More common than not to need a shim here, unless the pocket is already angled. The different type of bridge brings the strings further off the body, more like an archtop or Les Paul. Just like those models have necks that angle back toward the headstock, so must the Fender neck. I have a AV65 Jazzmaster (Wildwood thin skin), that has the angled pocket built in. Not sure if that was vintage correct, or a WW add-on. I don't know how many offset models have the angled pocket already...
    Same is going to be the case for these type of bridges, Bigsbys, etc, on Teles. It's not the body, it's the bridge height.
    kirby02 likes this.
  17. moosie
    Western Connecticut
    Hah, we cross-posted, with different ideas about Strats :).
    What are you thinking re Strats...?
    telemnemonics likes this.
  18. telemnemonics
    On a correct spec Tele I very seldom see the saddles all the way down with the strings above the board.
    I'd have to guess it was due to a lot of relief dialed in with the truss rod?
    IME that condition ("saddles couldn't go any lower") indicates too much relief, and tightening the truss rod for less relief puts the saddles in a good height range.
    adnydrum likes this.
  19. telemnemonics
    My memory says Strats have thicker bridge plates and saddles withe less adjustment range (more the vintage style), so to get the saddles in range the neck usually needs one or two layers of business card.
    Super Strats/ Floyds either get shimmed, have an angled pocket, or have a recessed trem.
    A vintage Strat with the trem floating also needs a shim because the bridge and saddles sit higher.
    It's maybe not so much that a decked Strat trem is higher than a Tele bridge, but once the screws are buried in steel saddles, you're out of range.
    Neck relief and (vintage Strat) saddle height need to be what they need to be, and neck angle sets the action for those two constants.
    This may sound backwards but trying to raise the saddles too high or lower them so the screws all stick out is worse than setting a neck angle that works with the other two settings.
    That's how I approach a vintage style Strat anyhow.
    kirby02 likes this.
  20. Wallaby
    Wallaby Tele-Holic Silver Supporter
    Midwest
    What geometry issue was solved with the shim?
