Polishing scratches on nitro laquer
Discussion in 'Finely Finished' started by znanjeiimanje, Feb 23, 2020.
  1. znanjeiimanje
    znanjeiimanje TDPRI Member
    Dark Side Of The Moon
    Today I decided to change strings on my AO 50's Tele and stupidly enough I was not careful enough and managed to scratch the headstock with the pegwinder next to the high e string. I learned the lesson the hard way - not to use the pegwinder and pay attention, but for now this scratch (although not too visible) is annoying me quite a bit.
    Started googling on possible solutions, I have seen Meguiar Scratch X as the recommended option readily available, but seems that the impressions are mixed as to if it contains silicone or no.
    Anyone with the experience of polishing nitro finish with any of the readily available products?
  2. 53Strat
    53Strat TDPRI Member
    I've polished a whole Highway One body with Meguiar's taking the satin finish through to a nice low gloss - no problems with that.
    It is still my go to Strat years later.
  3. Silverface
    Lawndale CA
    The only "polish" I am aware of that leaves no silicones or waxes is Stewmac's "Preservation" polish.
    But it's unlikely you can "polish" out a finish scratch. You MAY be able to get it with buffing compound (not rubbing compound) or it may need a drop-fill with thin superglue (you can search the procedures for this with Google).
    Personally, I'd leave it. You WILL get more of them. It's a guitar., and headstock scratches just happen. The only way to prevent them is not play it and not change strings.
  4. fasteddie42
    fasteddie42 Tele-Holic
    Tip of the Mitt
    A nitro finish guitar WILL get nicks, chips,scratches and dents.....
    By the you fix that one that's bugging you two more will pop up.
  5. eallen
    eallen Tele-Afflicted Silver Supporter
    Best to post a pic to see what you mean by a scratch. To some it means the size of a hair, other it is a grand canyon.
    I have used Meguiars 2.0 swirl and 305 finish glaze for years on nitro without a single problem with recoating with nitro when the need arises. The 305 is for ultra polish and specifically body shop safe. I used to also use some of their other rough and medium polishes before moving to clay bars and 3M liquid. Meguiars has a whole listing somewhere of body shop safe finishes. I have found them all to work without issue
    Eric
