Pod HD500x - what are you running it into at home?
Discussion in 'Modeling Amps, Plugins and Apps' started by jammers5, Jun 18, 2015.
  1. jammers5
    jammers5 Tele-Afflicted
    Mount Pearl NL
    Just wondering what everyone is doing at home....I run it straight into the board for gigs and practice but at home I run it into a practice amp (Traynor Darkhorse) which sounds COMPLETELY different. Was wondering what the alternatives were, don't mind dropping a few bucks to get a home set up that is similar to running it into a PA!
    J5
  2. Esprit
    Esprit TDPRI Member
    Essex, UK
    No experience of multi-FX units but interested in trying one. If the amp and cabinet sims are engaged can the unit be output directly to a home audio system? I assume that is the same in principle as connecting to a PA? Alternatively I understand a SS acoustic guitar amp is effectively the same as a PA so would that be a viable output option for milti-FX?
  3. Steve_U1S
    Steve_U1S Tele-Afflicted Ad Free Member
    Toronto, Canada
    I run my PODs (each generation - currently using HD Desktop) directly into my computer at home... then I can record at a moment's notice, etc... and is consistent with using it live into the board.
  4. jammers5
    Mount Pearl NL
    Now this is a great idea! Thanks! What output setting are you using?
    J5
  5. Jamie Black
    Jamie Black Friend of Leo's
    Neither here nor there
    When I had my pod hd300 I ran it into a powered harbinger PA speaker.
    Sent from my Apple Interocitor using TDPRI
  6. telleutelleme
    telleutelleme Telefied Silver Supporter
    Houston
    HD500 and I run the two line outs into an Alesis Multi-Mix 16. I also use the direct link to a DT50 amp which I can then mic and also bring it into the mixer. I actually have never tried driving another amp or even a cab out of the HD500 but should try it.
  7. Steve_U1S
    Toronto, Canada
    Direct mode - it's a perfect match; it's expecting wide range amplification in that mode.
    I do use a mixer simply to attenuate and make it convenient to get my friend's POD signal in there so that we can live-record and such.
  8. Guitarteach
    I use a Yamaha mini mixer MG10XU - acts as a USB interface to my MAC too for recording on a whim. Plug multi-fx in to mixer using the 'line out' setting on the multifx.
    It goes into my DAW, let's me mix back from my PC and plays through some powered Rockit5 studio monitors but a hi-if aux in would do on a budget
    Great price too.. Got multifx, two synths and a drum machine & sequencer through it now.
  9. PeterH
    PeterH TDPRI Member
    Johannesburg
    I'm about to finalise my fifth video in my series on the HD500X and this one deals with plugging the unit straight into the front end of a Marshall tube amp.
    A lot of users have mentioned that they get great tones out of it by going direct but being very disappointed when plugging into a guitar amp.
