TequilaCaster
I build all my 1x and 2x speaker cabinets out of 1/2" Aurauco ply, using simple butt joints and PE (gorilla) glue, no bracing required as the corners are strong, with 1/8" round-over routing on all cabinet edges for a nice finished look. I use corner clamps when gluing to keep things square, adding on one panel at a time. Polyeurethane glue dries quickly, and I remove the clamps after 2 hours, and add the next panel. I build the box first, then cut the speaker holes and jack panel holes. For open back cabinets (which I prefer), I calculate the total area of the openings in the speaker basket(s), and then cut the same size opening (or 5-10% larger) in the back panel. I use a 1/4" router bit and a simple circle router jig, so all the opening are circles, and it is super easy to do because all the surfaces are planes, with no obstructions. For grilles, easiest is an oversized round metal grille (for 10" speakers I use 12", 12" speakers get 15" grilles) screwed to the box.
I like 2 cubic feet minimum for each 12" speaker, 1.5 cubic feet minimum for each 10" speaker. For a 6.5" speaker I would go minimum 1 cubic foot per driver. I would use thicker ply for a 4x cabinet though.
