AriajazzJulio
Hi all. I know this has been asked thousands of times but I don't feel I've found an answer to it. I'm planning to built a stereo guitar amp with two 6.5" Emminence speakers, they are 20w each (4 ohms). My questios is: should I use 1/2 or 3/4 inch plywood. I've read many times that 3/4" is the industry standard for guitar cabinets but considering the one planned is kind of small (19x13.5x8 inches) I would think 1/5" thick could be enough, maybe I'm wrong and that's what I want to clarify. Here in Ecuador plywood is meassured in milimeters and not inches so the choices for thickmess are 15 and 18 mm. Working with 15 mm makes meassurements more precise and exact whilst using 18 mm complicates this factor.
I know about Baltic Birch Plywood which is not available in this country. In this case I will get the best that I can find. I plan to tolex the cabinet, and as far as I know this can help reduce resonance issues. The cab will be ported with 35mm holes. I know this design is not that easy to obtain good reults. A lot of math and calculation is involved but I want to help these little speakers to have more bottom end. Also will want to know about baffle material and thickness. Some experts say that MDF is better for it since is more robust
I will really appreciate your help and your thougts so I can have a clear idea of what to do and complete this project. I'm getting tired of reading and not getting a definitive approach and decision.
Thanks in advanced.
Thanks in advanced.
