Question for anyone who knows how this setup works.
It seems clear that if you connect a single speaker cable to either the "4 ohm mono" or "16 ohm mono" jacks, you get both speakers.
It also seems clear that if you connect a single speaker cable to the "8 ohm right" jack, you get the right speaker.
I'm guessing that if you want just the left speaker, you connect the speaker cable to the "8 ohm left" jack and insert another cable with no signal on it into the "8 ohm right" jack.
Thanks as always.
Thanks as always.
