please suggest me a cheap preamp/d.i.
Discussion in 'Acoustic Heaven' started by Albertwang, Feb 2, 2014.
  1. Albertwang
    Albertwang Tele-Meister
    Italy
    I want to put togheter a bunch of pedals and create a pedalboard for acoustic. I need a suggestion for a cheap di/pre (max 120 $) that can do the work. I play in a country/roots band and I have to face strumming parts and a pair of solo.
  2. Martin R
    Martin R Friend of Leo's
    Albuquerque
    We use Art Tube MP's for our two acoustics on stage.
    The tube doesn't do a lot but it's a very clean, cheap preamp that gives the passive pickups in our guitars plenty of power for the board.
  3. Greg.Coal
    Greg.Coal Tele-Afflicted Silver Supporter
    Colorado
    I guess cheap would be the Behringer acoustic D.I. People say it fuss the job.
    I have an ART MP: it has some uses but can't help you with anti-feedback or tone shaping.
    Greg
  4. Tim Armstrong
    Tim Armstrong Super Moderator Ad Free Member
    Austin, Texas
  5. gpasq
    gpasq Friend of Leo's
    Littleton, CO
    I do a lot of acoustic gigs and have recently moved away from the DI/pedal board, and I'm now using a Mustang III. Sounds great. I use the studio preamp setting with some reverb, some echo, some compression, etc as needed. Footswitch for solo work. Also sounds great with my mandolin. Goes direct to the board, plus I have a monitor if I need it. Oh, and eq.
    That's about twice your budget, but if you don't have to consider the cost of the rest of the pedal board, it might work. It's certainly flexible, and to my ears it sounds better than any acoustic rig I've played.
  6. FMA
    FMA Poster Extraordinaire
    What Tim said. It's a little more than your budget, but it's worth it.
  7. Edgar Allan Presley
    Edgar Allan Presley Friend of Leo's
    Colorado
    I use the Baggs Para DI, too. Actually, two of them: one for acoustic guitar and one for fiddle. I can get a really natural sound using them, dial out feedback, and use effects in the effects loop. It's a compact and effective acoustic rig.
  8. soulman969
    Englewood, CO
  9. krisls
    krisls Tele-Holic
    Sydney Australia
    The Baggs Para Di is a classic but personally I find it a bit fiddly. For your use with pedals you could look at the Ultrasound Ultra DI pre, should be in your price range, simple, solid and nice sounding. It is biggish though so if size matters, go the Padi.
    Kristina
  10. still_fiddlin
    still_fiddlin Friend of Leo's Ad Free Member
    I have the Ultrasound PDI, and it works well, but I did have one problem with pedals - when I used a few pedals (unknown which, but probably chorus & delay, also, magnetic soundhole pu) and tried to use a daisy-chained 1-Spot to power all of them, including the PDI, I had hum. It doesn't have a ground lift, and there was no way to get rid of it in that configuration, so I had to use it with a battery to eliminate the hum. It does run on phantom power, as well, but I didn't try that. (Actually a nice feature to have 3 different ways to power it.) It might have been the combination of pedals, but if you want to run everything off a single power source, make sure to test *whichever* preamp-DI you get. Or, plan to use batteries!
    (This thread reminded me about it - I no longer use it since I have a guitar with a built in pre, so it's headed to eBay this weekend, if I can keep it in the front of my mind to remember it by then :).)
  11. Albertwang
    Italy
    Once again I hada lot of good advices
  12. studio1087
    studio1087 Telefied Silver Supporter
    Near Milwaukee
    K&K Pure Preamp - Link
    $85 USD. Fantastic little preamp. You can wear them but I clip mine to the handle on my acoustic amp.
  13. JG806
    JG806 Tele-Holic
    Amarillo TX
    Behringer ADI-21. I prefer it over the Baggs Para. Really can't go wrong with it at the price even if it becomes a backup.
  14. DaveKS
    DaveKS Friend of Leo's
    KS
    Look for a HK metal shredder preamp, don't let the Metal name fool you. , set gain knobs abut noon and it s about best clean preamp you could want. Its f'n awesome.
  15. Albertwang
    Italy
    Since I have a fishman prefix preamp on my guitar...I suppose I have to buy a passivd di...
  16. still_fiddlin
    You don't *have* to but it's probably all you'd need for live gigging. Of course, there are folks that use both (i.e., onboard + external PDI), but assuming you've got EQ on the guitar and at the PA, you should be able to get a decent sound and manage feedback without needing a *third* preamp.
    A plain, passive DI will set you back $40 or so here. You can spend a lot more, but for live use, and if it's fastened to a pedalboard (not being beaten around), that's all I'd probably go. I've got a LiveWire model and it works fine. I also have a Radial that I use when it's me alone, no effects, with my Martin, but that's $100, and nobody in the audience can hear the difference, I'd bet. Maybe if you were recording.
    My $.02, anyway.
  17. Radspin
    Radspin Friend of Leo's
    Long Island, NY
    For what it's worth, I tried to go cheap with the Behringer preamp and it was defective out of the box. The other acoustic guitarist in my band hasn't had a problem with hers. I bought the Baggs Para Acoustic DI and it's worth every penny. It makes every guitar and electric uke I play through it sound great, sounds great through a PA or an amp (I play my electric uke through a Princeton Reverb to give it some character) and is a solid, professional, rugged piece of gear. Spend the extra money if you can (those eBay auctions sound promising) and you'll never regret it.
