BluegrassPicker
I'm in the process of installing a CuNiFe WRHB in place of the existing MIM WRHB which I installed several years ago. I'm not the original owner of this original '72 Custom (not RI) and it appears that someone has completely changed the wiring from stock to a method that I'm having trouble identifying from information here and on the web.
There is a treble bleed on both volume pots on this guitar, and it doesn't look like the 50's or Modern LP wiring that I've seen on the web, and it is not the OEM Tele wiring from the diagrams that I've compared this with.
Additionally, there are 1meg volume and tone pots on the WRH neck circuit and 256k pots on the bridge PU which is a single coil Tele pickup (possibly OEM but unknown).
I don't mind if I have to re-wire this completely for the best results, but I'm not sure if I should leave the configuration as-is or re-do it all in a more appropriate or better configuration. The guitar functioned what I consider to be normal previously, so if the consensus is that it's better as-is, then I'm ok with that as well.
I would greatly appreciate any comments, suggestions or input for the best way to proceed - redo to stock Tele '72 Custom wiring, redo for 50's, Modern LP, tone bleed or no, or whatever might be best. My question for those who have experience in this situation is "what would you do"?
My goals and usage is for a twangy and clean country tele, not heavy metal, and probably just using the volume and tone controls wide open with no or minimal adjustment while playing.
Also, while I'm "under the hood" doing this, I'd like to put in the best combination of pots to complement the Fender CuNiFe WRH and the existing Tele single coil in the bridge. 1megs for the neck and 256k for the bridge or 1megs for all or 512k's? Again please let me know what you would do.
Thanks in advance, I appreciate any assistance with this project.
BluegrassPicker
Here's the wiring that is in the guitar now:
BluegrassPicker
