Please help me find a SIMPLE boost? Thanks!
Discussion in 'The Stomp Box' started by richedie, May 30, 2013.
  1. richedie
    richedie Tele-Meister
    Chesterbrook, PA
    Hi guys!
    Can I ask a question around this pedal? I use my amps' gain for everything, I don't use OD pedals and have no desire to fuss with them. For all flavors of gain, I use my amps - Bogner Shiva, PWE Event Horizon and modified Dual Rectifier.
    Now, for some songs, I have my amp gain barely opened up, so rather clean. For example, we play a Matthew Sweet song, Sick of Myself. On this song, I have the gain at like 9:00! When I go into the leads (lots of solos on this tune) my built in amp solo boost only adds volume. I want to add thickness, gain, sustain and maybe mids for the solos.
    For this I like simplicity and not too expensive. Transparency is also key. What about any of these? Others? Keep in mind transparency is over rated. A pedal will always color the tone, it is the nature of the beast, but lets face it, some sound way more natural and blend with various amps than others.
    Keeley Katana or Java Boost, Xotic EP, Love Pedal Amp 50, Electro Harmonix LPB-1, or others?
    Simple is key! I don't want to be fussing with knobs. :)
    Must be analog. Not digital.
    Thanks! :)
  2. waparker4
    Philadelphia, PA
    I recommend the BBE Boosta Grande. EHX LPB-1 and MXR Micro Amp will work too. I don't see a reason to break the bank on this, IMO and YMMV.
    The TC Spark Boost looks very cool imo.
    The Dingotone HZD Boost looks cool too imo.
    Those last two have multiple knobs. BBE only has one knob.
    There is a recent thread in the Stomp Box, with many suggestions http://www.tdpri.com/forum/stomp-box/404966-recommend-clean-boost-true-bypass.html
    Also, this
    sounds like you are describing a tube screamer. Again, ymmv
  3. richedie
    Chesterbrook, PA
    Thanks, must be analog and sound very natural. I don't want it to sound and feel like I kicked on a pedal. For example, my Sonic Edge J&J Overdrive feels like an extension of my amp. Maybe I just use that?
  4. MikeMurray
    MikeMurray Tele-Holic
    South Africa - Pretoria
    Or use your guitar's volume control. Or a volume pedal.
  5. Gunerius
    Gunerius Tele-Holic
    Norway
    Sorry, but transparent? Really? You want a pedal that doesnt sound like anything? Use your guitars volume knob! Hehe, only joking.
    I am happy with my lpb1, but its not "transparent" it sounds like you kicked on a pedal, it adds some bottom and grit. Works perfectly for me for what you asked for
  6. waparker4
    Philadelphia, PA
    BBE Boosta Grande is like that
    My reference is strats and teles into DRRI. boosta makes it sound like LOUDER STRATS AND TELES INTO DRRI
  7. richedie
    Chesterbrook, PA
    I thought about that and have done it that way, but never works as well as I like. I prefer a pedal for the boost.
  8. richedie
    Chesterbrook, PA
    Thanks for the input!
  9. soulman969
    Englewood, CO
    TC makes great pedals and their Spark Boost should work nicely for you. I have it's daddy, a classic boost + distortion, on my board and it's a great pedal either way I use it but most of the time it's used a simple clean boost like you're looking for.
  10. robt57
    robt57 Telefied Ad Free Member
    Portland, OR
    Pickup Booster by Duncan, or as said tweak the front end of the amp with your git vol pot @ 3/4 so when you open up the guitar it gets you there.
    That one is easier to try of course...
  11. Ed Boyd
    Ed Boyd Tele-Afflicted
    Illinois
    I never know what people really want on forums. Personally what works for me depends on the guitar.
    For single coils something along the lines of the BBE or Visual Sound truetone boost works well but for humbuckers I have better results with a switchable 10 band EQ. Especially with EL tubes. Can't explain why.
  12. richedie
    Chesterbrook, PA
    Thanks, I love TC pedals! Is the Spark Boost, analog???? Please say yes. And does it compete with the Green Rhino? :)
    I don't want a clean boost. I want to add gain for sure, maybe some comp and mids.
  13. backsideslappy
    backsideslappy Tele-Afflicted
    I generally use a TS clone with the gain zeroed and the level and tone dimed and it opens things right up, maybe a pinch of gain if I want a bit more drive, but mostly zeroed. Works great. Probably not what you're after, but I thought I'd throw it in there.
  14. richedie
    Chesterbrook, PA
    That is awesome! I finally tried my J&J Overdrive like that, Volume and Tone maxed but Gain down low, about 9:00. Maybe I am OK without a tube screamer because using so little gain at the amp, I don't need lots of mids to cut through on solos, the J&J with the volume up really boost my signal and makes everything louder, thicker with great sustain for leads! When I run my amp with medium or high gain, I use the amp's solo boost.
  15. Dave_O
    Dave_O Friend of Leo's
    offline and IRL
    Simple boost?...
    Leave the EQ sliders flat, and boost the output. Doesn't get much simpler.
  16. waparker4
    Philadelphia, PA
    Yeah it does :p
  17. CajunPicker316
    CajunPicker316 Tele-Holic
    Lafayette, Louisiana
    Xotic EP Boost
  18. Davo17
    Davo17 Friend of Leo's
    Southern California
    +1 on the EQ.
  19. Lunchie
    Lunchie Poster Extraordinaire
    Downstate Illinois
    Zvex Super Hard On, bit cashy new but can be had used. One knob, cant get much simpler and they sound awesome.
  20. JayDee
    JayDee Tele-Meister
    Missouri
    For your needs, I'd recommend the Visual Sound Truetone. I love it. It replaced a Durham Electronics Sex Drive on my board, which is a fantastic pedal in it's own right. You should be able to find one used for $60 or so.
