Playing laptop through (modeling)amp
Discussion in 'Recording In Progress' started by schmintan, Jan 29, 2020.
  1. schmintan
    schmintan Tele-Meister
    Ireland
    My home setup, purely for practicing is a small yamaha THR10 modeling amp, and a laptop that sits in a docking station attached to a keyboard and monitor. thats it.
    When the kids are asleep, i need to use headphones, so i need to put the laptop through the amp. This is easy, as the amp has an aux in, but when i connect the laptop using a 3.5mm jack cable, there is a lot of hissing, buzzing and general interference. it goes away completely if i unplug the laptop and just plug in my phone.
    I found the cause of the issue, its either the monitor or the monitor cable.
    Ill replace the cable, but what i am asking is will a USB audio interface to the laptop eliminate all that interference?
  2. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    Doesn't the THR10 have a built in USB interface? Try plugging the guitar into the THR10, then USB to the laptop, then plug your headphones into the laptop.
  3. schmintan
    Ireland
    it does! i had forgotten! Ill give that a go and update here. thanks!
  4. Digital Larry
    Digital Larry Tele-Afflicted Gold Supporter
    Silicon Valley, CA
    I used USB with my Windows laptop and THR10C and Cakewalk and it worked fine.
    Allan Allan likes this.
  5. schmintan
    Ireland
    that worked! I had completly forgotten the thr can connect to a computer via usb. totally resolved my problem, but now i dont have to buy new gear :(
    Thanks !
  6. Larry F
    Iowa City, IA
    Incorrect, sir. One always needs to buy new gear.
    suthol and Frodebro like this.
