SpHowe3319
I'm mentally wrapping my head around the Tele build process, and attempting to get my math skills in order well in advance. My key question, followed by my current roadblock, is...how do you know how thick the neck and fretboard should be for a Telecaster with a Modern C profile? I understand it partly has to do with the bridge.
While I save up for a copy of Making Your Electric Guitar by Melvyn Hiscock (which I hope will help my pitiful math skills), I have been using this Tele build series by Tchiks as a pseudo-101 course. It's what got me into the hobby in the first place, and how I formed some of my building comprehension. This forum has been very informative, and just as helpful.
At 1:43 in the linked video, the builder states he is marking the neck pocket 16mm down from the top of the body. This is to ensure the fretboard sits 9mm above the body because the neck and fretboard are 25mm combined.
This is where I get bogged down, because my measurements differ from his when I follow his instructions. This is likely something I did wrong.
The builder used a Modern C neck. Based on a set of Fender Neck Profiles I found, the Modern C is .870", or 22.09mm at the 12th fret. The builder's cut list stated the fretboard was 6.35mm prior to radiusing. This would put the 12th fret's thickness at 28.44mm, leaving the heel far too thick for a pocket that is 16mm deep.
If it were a matter of 1-2mm, I would think the neck pocket could be deepened, or the heel could be planed to meet the specs. I'm feeling more confused about neck building now...wondering how to wrap my head around this. If anyone has a detailed neck build, or example they can share - it might go a long way to helping my tired brain.
Thanks all,
Showe
Thanks all,
Showe
