ArcticWhite
I'm planning on building a Model 26 Woody using transformers and field coil speaker from a 1946 Philco Record Player Radio console.
Any mods I should consider off the bat? I know that the tone control isn't safe as is, it puts 375 volts across the pot, and thus, needs a cap across the naked side, and both caps should be rated at 600v or so.
I guess I should add 1500 ohm grid stoppers before the power tubes.
Anything else?
My Philco field coil speaker is a 12" instead of the ten inch original. I'm on the fence about building with a different set of iron altogether and using a ten inch, but I've never built a field coil amp, so I'm kinda excited about that aspect.
Also gotta figure out how I'm going to cut this chassis down a bit, to make it work in a combo cabinet in some way...
Time to get out the grinder.
Anything else?
