Placing O.T. outside the chassis?
Discussion in 'Amp Central Station' started by italo, Sep 7, 2017.
  1. italo
    italo Tele-Meister
    Argentina
    Dear TDPRI experts: I´m looking forward to a Single Channel ab763 build but the combo cabinet i got is very shallow and I´m having trouble with interference between the speaker and the transformers. I can clear the power transformer but not the Output transformer.
    The question is: is it OK to screw the OT outside the chassis ??( for example to one side of the cabinet )
    will the longer wire runs affect hum? Should I twist them?
    Thank you all !!!!
    Best regards
  2. Silverface
    Lawndale CA
    It's hard to answer without a picture. But you for sure do not want to run speaker wires anywhere near AC power or high-voltage wires. The orientation (vs that of the power transformer) is important - again, without seeing the layout it's hard to tell.
  3. bparnell57
    bparnell57 Poster Extraordinaire
    Philadelphia, PA
    Mounting it internally would be better. External mounting would be fine, but not advisable.
    Plenty of amps did it back in the day. Today you can't because of the B+ on the transformer leads.
  4. bparnell57
    Philadelphia, PA
    For UL purposes that is.
  5. Dacious
    Dacious Poster Extraordinaire
    Godzone
    You could mount a separate sub chassis on the side or bottom like the Fender Excelsior. Lots of old non-US amps had separate power supplies. Just need to protect/shield the wires to avoid inadvertent electrocution contact.
    Edit: just noticed you said o/t. Plate leads? Mmmmm probably not wise. O/t is relatively small. It could go off to one side without harm, lead dress could be finicky.
  6. italo
    italo Tele-Meister
    Argentina
    Thanks for your inputs!! I will add some photos to clarify my question
  7. Mike Simpson
    Gilbert, AZ (PHX)
    On early Tweed amps isn't the output transformer mounted on the frame of a field coil speaker and the common way to replace it with a permanent magnet speaker is to mount the OT to the side of the cabinet?
  8. italo
    italo Tele-Meister
    Argentina
    That´s where my idea/question comes from. Is there any harm to have long B+ and plate wires?
