Pining for Pine?
Discussion in 'Tele Home Depot' started by El Chivo, Oct 12, 2015.
  1. El Chivo
    El Chivo Tele-Meister
    Los Angeles-ish
    I just started the luthier program at Musicians Institute and have a question for y'all. In class I've asked a couple questions about using Pine and have been told that it doesn't make a good wood for a build because it's "unstable." When I pushed for clarification I was asked why I was "fixated" on it.:lol: I was told that Pine is too soft a wood for guitars and that screws would eventually loosen and strip out. It seems that quite a few builders here have used this wood. What is your long-term experience with it?
  2. guitarbuilder
    That answer sounds like BS. Do a search here for pine body builds. I have made at least 50 bodies out of the stuff.
    A guy named Arlo West popularized the wood for tele builds a few years ago. His pix are gone but the threads remain.
    http://www.tdpri.com/forum/telecaster-discussion-forum/57082-barncaster-100-year-old-pine.html
    http://www.tdpri.com/forum/tele-home-depot/197040-maine-pinecaster-build.html
    http://www.tdpri.com/forum/tele-home-depot/166992-ol-piney-overhaul-2009-a.html
    http://www.tdpri.com/forum/guitar-owners-clubs/175019-pinecaster-club.html
    Oh by the way... the Fender Company makes pine telecasters and the squier line of Classic Vibe teles are pine bodied.
    http://www.ebay.com/itm/Fender-Old-...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
  3. Mike Simpson
    Gilbert, AZ (PHX)
    I would not make a neck out of pine but it has been done. There is no reason not to use pine for a body... I have made 4 guitars with pine bodies and have around 400 gigs on one of them. Be aware that any knots will eventually be visible in the finish.
    If you get that kind of answer about pine I would be concerned about the actual knowledge of the instructor and what else is incorrect.
  4. Jack S
    Jack S Friend of Leo's
    Berwyn, IL
    One thing to consider is the age of the wood makes a large difference in how hard the wood can be and how well it will hold screws. If you have pine from a 100 year old barn, it will not at all be similar to a piece of wood you will buy at a lumber store, unless they specialize in old recycled lumber. I have some pine lumber that came out old houses that is pretty darned hard to just hammer a nail into, and that is the reason most contractors want to tear out old lumber and use newer stuff. It is much easier to work when they are trying to work fast and move onto the next job.
  5. guitarbuilder
    My last pinecaster was made from Lowes pine, including a pine neck. It's one of the nicer guitars I made the past few years. I went down one size on the neck screw pilot holes to allow them to make a bit of compression during the initial thread cutting compared to what the pilot hole chart said. No problem holding tight. If I was removing the neck regularly, I'd put some superglue down there. The body holes don't hold the neck in place anyway...They are a touch larger than the screws, and then there is the neck plate to provide support. The worst case scenario is that the plate will cause some mild indentation and compression on the bodywhen you torque the neck screws down. That can happen on any wood that has a lesser density.
  6. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    Generally.. the pine most are familiar with is construction grade. it's rarely dried to the 10% or less most choose for furniture, guitars, or anything similar...
    it can warp crack, split, all kinda things ya don't want your guitar doing after you've completed it...'
    Ya have to be careful when suppliers throw around ambiguous words like Stable. Like what?? ya mean if ya sit it on a flat surface it wobbles... or if surrounded by a "focused" explosion it goes radioactive and explodes... or if you have it in your trunk and hit some bumps it explodes (nitro ya know)... ;)
    However, there are many quality lumber suppliers that can provide properly dried pine, which is every bit as good as any other generally "approved" lumber commonly used for guitars.
    One caution, Pine is usually a pretty resinous species, any amount of drying will not address that goop.. only time allows the sap to solidify...
    there is some old fat guy that posts occasionally here that makes a lotta guitars from really old pine, and has has considerable success with 'em. but he's stuck in NE Florida, surrounded by hillbillies... and distracted by the Game the Gators will be playing next week..
    Ron Kirn
  7. niilolainen
    niilolainen Tele-Meister
    Helsinki, Finland
    Squire Class Vibe 50s Tele has a pine body.
    So does my Vintage Modified Squier P-Bass. Heavy as anything...
  8. Tear
    Tear TDPRI Member
    Columbus, OH
  9. TRexF16
    TRexF16 Friend of Leo's
    Tucson
    If there's a building materials salvage yard anywhere nearby, take a trip over there. Look at both the pine beams they have as well as the old reclaimed doors. If you can find old beams that are 2" or more thick (4" is great, you can resaw it!) you'll be way better off than using Construction grade dimensioned lumber.
    Rex
  10. trev333
    Coolum Beach,Australia
    this old pine table was like hardwood to work with...
    the finished blank was @ 4 1/2 - 5 lbs.... not heavy.... hard as hell to sand/rout, though... 250 grit would just polish it and ruin the paper, without hardly a scratch...I think I finished it with fresh 120?.......;)
    there's Pine.. and then there's Pine....:lol:
  11. Zipslack
    Zipslack Tele-Meister
    Mississippi
    I would always worry about sap/resin. Unless it's 100 years old, you never know when temp changes will causes it to come out to haunt you and ruin the finish.
  12. Mr. Lumbergh
    Initech, Inc.
    That's a beaut Trev.
  13. TRexF16
    Tucson
    Thiscan be mostly controlled by using shellac as the initial finish under lacquer. It's a great sap sealer.
    Rex
  14. Tear
    Tear TDPRI Member
    Columbus, OH
    zinnser bulls eye is what i used to seal up my build
