Pine wood whitewash finish
Discussion in 'Finely Finished' started by Jake_the_tech, Sep 1, 2020.
  1. Jake_the_tech
    Jake_the_tech TDPRI Member
    Bothell Washington/ mcminnville Oregon
    Hey all!
    Long time lurker first time poster here. I'm going to be building a 51' spec tele out of pine and I want to put a whitewash finish on it where you can still see the grain. I have plenty of experience working on guitars and I'm pretty good at woodworking but painting and finishing are areas where I'm pretty green still. If you guys could help me out with the whole process and what products you'd recommend that would be great!
    Thanks!
    Jake
    Lake Placid Blue likes this.
  2. adjason
    adjason Poster Extraordinaire Silver Supporter
    virginia
    experiment on scrap is all I got-reranch sells some paint that might work with a thin coat
  3. mfguitar
    mfguitar Tele-Afflicted Silver Supporter
    Buffalo
    I have used latex paint thinned out to get the color I want and then coated with Poly. There are specific "pickling" stains out there but I don't find them needed. Sound advice above practicing on scrap as pine can take color unevenly. Good luck... and post pictures!
  4. Jake_the_tech
    i plan on practicing on the scraps after cutting out the blank so i can see exact way my wood will take the finish
  5. Jake_the_tech
    Latex? interesting take! through hours of research you're the only one ive seen use latex paint. i think ill use an amber shellac to darken the grain, a white wiping stain so i can get the level of white i want, and then a spray on clear gloss finishing lacquer. note that im just going off youtube videos and forum posts so i dont know if all that is needed or not.
    El Tele Lobo likes this.
