Pine cabinet vs particle board tonal differences?
Discussion in 'Amp Central Station' started by Cadillac_Mike, Jan 19, 2021.
  1. Cadillac_Mike
    Cadillac_Mike Tele-Meister
    River Falls, WI
    I know a lot of you guys have played tons of different amps that likely have both so I'm really curious how much you can hear that difference alone. All the higher end amps seem to have real pine cabinets but doesn't the speaker basically just shoot the sound straight through? It seems like the quality of the wood wouldn't make a ton of difference shaping the sound unless you're using reverb.
    drewg likes this.
  2. uriah1
    Around
    Well some swear by black face super reverbs. Most 60s were particle board.
    RichCuellarPDX, dang and CCK1 like this.
  3. loopfinding
    loopfinding Tele-Afflicted
    europe endless
    i'm not sure it really makes too much of a difference, but i'd sure as hell rather lug a pine cab around than MDF.
    kookaburra, Alamo, Maguchi and 24 others like this.
  4. jman72
    jman72 Tele-Afflicted
    Central Florida
    I use pine for all my cabs. When you're playing, the whole cab vibrates (especially if you use a floating or thin baffle), so I like to think of the whole thing resonating like an acoustic guitar. It's probably not THAT big of an effect, but you can imagine that it makes a difference when the wood is absorbing some vibrations.
  5. Fiesta Red
    Fiesta Red Poster Extraordinaire
    My back and surgically repaired shoulder says pine is better than particle.
  6. Ess Eff
    Ess Eff Tele-Afflicted
    Earth
    This has been done to death.
    The cork sniffers swear by ply/pine. You can hear the diff, feel the diff, taste the diff, etc.
    Other ppl don't care/can't tell.
  7. slider313
    slider313 Tele-Afflicted Silver Supporter
    NC
    The cabinets were pine. Only the baffle was particle board.
    kookaburra, Maguchi, swany and 15 others like this.
  8. Cadillac_Mike
    River Falls, WI
    That's funny, I didn't even consider the weight difference. My Blues Junior does seem a bit hefty for its size.
    Maguchi and Reivaj like this.
  9. Cadillac_Mike
    River Falls, WI
    Did all Silverface amps have pine cabs?
  10. Jbnaxx
    Jbnaxx Tele-Meister
    Arkansas
    In my limited adventures in cab building, I find that solid pine cabs have a bit of a woody ring to them. Birch plywood seems to not have that ring to them...... never worked with particle board.
    edit: I expect in an amp cab after it’s covered with telex, you couldn’t tell the difference.
    greenhornet, PhredE and Cadillac_Mike like this.
  11. PhredE
    PhredE Tele-Afflicted
    Suburban PDX, OR
    My 0.02..
    I guess I'd have to agree with most of the previous comments. Perhaps the biggest differences probably isn't in the sonic qualities so much but more in weight and/or strength. Having said that, I will add.. when I have built my own with solid pine, inevitably I do a good pass over the exterior with a random orbital and/or finishing sander. When I run the sander(s) over the [mostly] finished box, it will resonate at a certain frequency and the volume of that vibration can be astonishing loud! I like solid pine finished in a clear coat --- not because I'm picky about appearances and styling, but because it is easy to touch up, strong as heck and lighter than ply or particle or OSB type materials too.
    YMMV. Good luck.
  12. Rockinvet
    Rockinvet Tele-Afflicted
    Virginia
    For me it's the weight. You'd have to have really good hearing to really notice the difference. So I lose on both accounts!
    Maguchi and Jakedog like this.
  13. strat a various
    I'm absolutely certain the wood affects the tone of a solid-body guitar.
    I'm absolutely certain the wood (ply or particle) DOESN'T affect the tone of a guitar speaker cab (at the same thickness).
    Absolutely.
    Certain.
    Cadillac_Mike likes this.
  14. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Pine is lighter. Particle board can swell and disintegrate if it gets wet
    Later Silverface cabs the top and bottom were pine, the sides and glued in baffles were particle board. They definitely weigh more - 5,6 lb for my late Princeton Reverb.
    Early Drip-edge, the baffles were detachable, cheap screwed-in compressed particle board that crumbled with age. I'd replace with 5 ply myself.
  15. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    I stripped the Tolex off my PRII, and it really opened up the tone and let the pine breathe.
    Maguchi, Pasta Player and rjtwangs like this.
  16. Dan_Pomykalski
    Dan_Pomykalski Tele-Meister
    Madison, WI
    Pine is super light, super cheap, and super easy to work with. Even if there wasn’t a tonal difference, I’d probably still build my cabinets out of pine.
  17. drewg
    drewg Tele-Meister
    Oregon, USA
    I briefly owned a 60s Gibson Minuteman and that particle board was a sponge of stale dankness (probably exaggerating slightly). That, and its less than satisfactory sound made me get rid of it.
    I want to believe pine resonates better – and it makes sense that it would, over time, if only subtly so – but even if it doesn't (as you say) I won't buy another MFD amp. I like well made furniture with real wood. Nothing says cheap like particle board– not to mention all the chemicals in the glue. (I wish Vox would stop using the stuff).
    Maguchi and Dan_Pomykalski like this.
  18. Michael A.
    Michael A. Tele-Afflicted
    Virginia Beach, VA
    I'm also curious about a related question, which is whether changing from a particle board baffle to a Baltic ply one will have a sonic effect. Specifically, is it likely to be brighter?
    drewg likes this.
  19. strat a various
    It adds chime.
    Michael A., mojek and drewg like this.
  20. Dacious
    Godzone
    I don't think it makes much difference.
    Michael A. likes this.
