Davecam48
Hi All,
Got in yesterday and wacked together a little pin router attachment from scraps and bits and pieces laying around, The main material was a few bits of non-structural pine studs. These were scraps so the build size was determined by the longest piece available to form the overhead arm which is fixed at about 5" high in your money and 6" bit to base clearance, I made some hold downs to secure it using the track system on my home made, micro adjustable, mobile router table. Two hold downs look enough but it was built so I could also use a couple of clamps on as well and it can move around the table and secure on either of the four sides or at an angle.
I've already used it this morning to cut some rebates for a mobile base for a small equipment table, and wow! I should have had one of these years ago.
Anyway have attached a couple of pix for your listening and dancing pleasure.
Haven't done a detailed calibration on it yet, and I've only made a 1/2" pin but it is really accurate and I think it will be very usefull and lots of fun.
