PIN 6 on output tubes & grid stop/screen resistor...
Discussion in 'Shock Brother's DIY Amps' started by 0 2339, Jun 12, 2019.
  1. 0 2339
    0 2339 TDPRI Member
    oeste - portugal
    hope i can make myself clear on this one:
    looking at terminal designations of output tubes (el34, 6l6...) pin 6 is not used. they also don't show up on most schematics.
    yet, when i look at layouts i always see them connected to ether pin4/screen grid or pin 5/control grid - and not only that, usually the resistor that is only shown connected to pin4/5 in the schematics is wired between pin4/5 & 6...
    can someone share some light on this?
    thanks
  2. danlad
    danlad Tele-Meister
    Here and there
    Just a bit of point to point wiring. Mounting the resistor on the socket so its oscillation damping properties are a-ok.
  3. Greg_L
    Greg_L Tele-Holic
    It's usually just a convenient anchor point for one leg of the screen resistor and screen supply wire..
  4. 0 2339
    0 2339 TDPRI Member
    oeste - portugal
    alright, that makes sense - thanks guys : )
  5. Wally
    It is even more interesting to get off into some high fidelity amps and see how some designs use the ‘open’ pins on a rectifier. As with that pin 6 and pin 1 on a 6L6/6v6 tube in Fender amps, those unused socket points are used as terminal points for connections. These connections have nothing to do with the rectifier in these cases.
