Pignose Amp Owners Club
Discussion in 'Amp Owners Clubs' started by rangercaster, Jun 12, 2009.
  1. Jeremy Blaze
    Jeremy Blaze Tele-Meister
    New Washington, IN
    Another G40V owner here.
    Mine is stock other then the Tubes, installed some Electro Harmonics units a year or so ago.
    I am thinking about building a bigger cab for mine, or making it just a head unit, and building a big cab. Also want to modify it to make the precense knob more useful.
    Overall great amp with lots of head room for me.
  2. bluezguy
    bluezguy Tele-Meister
    West Pasco Florida USA
    Battery Packs Needed. Waz About 9Volt?
    Greetings fellow Pignoserz :lol:!!
    I've had my 7-100-(R) for a number of years and it has stopped working in battery mode as the connections have rotted off right at the terminal joints in both black plastic battery packs.
    The Pignose website doesn't sell a parts solution. Do any of yaz know where one could buy new replacement ones??
    Secondly, do you think ONE 9Volt battery would do the same job if I replace all 6 - 1.5V without doing any harm? I mean, nine volts is 9 volts in this case isn't it??
    I suppose I could try it but, I'd rather hear from anyone who has tried it first. It seems to me that one 9v battery would be cheaper than buying 6 - 1.5v and, a 9v battery clip which would screw right in place of the black plastic one is peanuts in price.
  3. Newzpix
    Newzpix TDPRI Member
    Near Mount Vernon, Va
    I have a 1974 7-100 fuzzy tone machine. image-2047505340.jpg Eric Clapton with his 7-100
  4. Johns62312
    Johns62312 TDPRI Member
    Bowling Green Mo.
    I just received a Pignose 7-100 and it seems to have the same problem that somebody else brought up on here about a underlying distortion behind the notes even when it is just barely turned up. The preamp out does the same thing into another amp so I know it's not the speaker. I see the Pignose Industries website has been suspended, does anybody have the email address that was on there. Anybody else have a problem like this. I have a real old one in a shed at my brother's house and I don't remember it doing this.
  5. Lazerface
    Lazerface Tele-Holic
    I believe this would work, but it seems to me that if you're using it a lot, the 6AA batteries will last longer than a single 9v and be cheaper in the long run.
  6. shanghaitele
    shanghaitele TDPRI Member
    Shanghai
    That is his sound....
  7. Johns62312
    Bowling Green Mo.
    Would anyone know what year a 7-100 would be with serial #4021? I just dug this out of a shed where it's been for about 20 years. It has a really bad static noise and I believe it's probably one of the transistors. I cleaned the volume pot and it still does it. Anybody know what's going on with the pignose website? I was just on it the other day and now it says it's been suspended. Anyone have their phone # or email address.
  8. MrCairo46
    MrCairo46 Friend of Leo's
    Baltimore, Maryland Hon!
    Oink oink !!!!!!
    gotta Pig and a US Blues Hatbox amp
  9. mudshark
    mudshark Friend of Leo's
    Groover's Paradise
    7-100 here...i dig the pig
  10. Johns62312
    Bowling Green Mo.
    Howard at Pignose just emailed and told me that serial# 4021 is a 1972 model.
  11. Johns62312
    Bowling Green Mo.
    So I heated up the board with a hair dryer and the static went away for a little bit. I thought I would touch a solder gun on each transistor one at a time and tried the first stage first and the static went away. Played it for about a hour and it's still good. I think I like the sound of the new one better but that might not be a fair comparison since the old one doesn't have the original speaker in it. I think I picked that one up at Radio Shack 20 some years ago. Sure would like to have a new replacement board to put in.
  12. SeeMoore
    SeeMoore NEW MEMBER!
    Virginia
    New to the forum and new owner of the G40V.
    Got mine last week, used it at a gig that night, first 30 minuets were great, loved the tones I was getting, then the volume starts dropping, sound gets very distorted, please tell me it's just tubes!
  13. Telesavalis
    Telesavalis Friend of Leo's
    Deep in the Heart O Texas
    +1
  14. Tee1
    Tee1 Tele-Meister
    London, UK
    You mean its sound? Then why have i heard 7-100s which don't make this fizz?
  15. SeeMoore
    Virginia
    Replaced the tubes, replaced the speaker, still have the same problem, low volume, distorted sound.
    Could it be transformers???
  16. Dauntless
    Dauntless Tele-Meister
    Cincinnati, Ohio
    If I remember right, didn't the G40Vs have problems with their output transformers? :eek:
    I remember a few people having to change out their OTs.
  17. Jeremy Blaze
    New Washington, IN
    ^ yeah, mine had it replaced.
  18. RayG
    RayG TDPRI Member
    E. Washington
    This is true. I think the voltage of 6 AAs (1.5v each) matches the 9v. Anyway, it works. I did this to a 7-100 which I got from someone who was getting rid of it because it sat for decades with AAs in it. Corrosion everywhere. I couldn't find the right 3xAA parts locally, so I just put a 9v in there. A clip on one side for the battery I'm using, and a clip on the other side for a spare 9v, because, yes, the 9v batteries won't last as long as the AAs.
  19. Newzpix
    Dating a vintage Pignose. Remove the black metal shield over the electronics - 4 screws. Lift it back - wires go thru an opening in it so be careful. The date your amp was born should be stamped on the wood and visable. I had to loosen two screws anchoring the board to see the year.
  20. napalmbbq
    napalmbbq TDPRI Member
    Lakewood WA
    Officially a member of the Pignose club as of a week ago. Picked up a G60VR last Friday for $128 at a local pawn shop. To my great fortune she came with Winged C tubes throughout, and she sounds outstanding. I'm shopping around for an alnico speaker and new knobs.
    Here she is.
    http://i.imgur.com/TrqIpLl.jpg
