So -
I just got an hvlp gun for work. I’m wanting to use it for guitars as well. Picked up some clear gloss nitro lacquer from rockler (haven’t tested yet), some mixol, & some transtint dye. But I’m thinking the clear lacquer is not intended to make solid colors? I tried some googling but came up empty. What do you all use for solid colors? And what sort of ratios do you recommend?
Thanks!
Charlie
Also-I am open to using poly/acrylic! Just want whatever’s easiest. I like the way lacquer lays down, dries so quickly, and how the coats burn into each other
Thanks!
Charlie
