Pickups too Bassy
Discussion in 'Tele-Technical' started by Tle4, Dec 14, 2019.
  1. Tle4
    Tle4 Tele-Afflicted
    Warrington, Pa. USA
    I have an American Standard Tele with bound neck. It has the Fender CS Broadcaste and Twisted tele pickups in it. I like how they sound pretty much except the low E and A are very bass heavy. I notice it mosty when I am trying to get OD tones. I also have a 52 Hot Rod Tele and I really like how the bridge Pickup sounds with OD. Is there anything I can do to tighten the bottom end when I add OD? Different value pots? Pickup Height? tone cap change?
  2. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Drop bass side of pickups, raise treble side.
  3. Tle4
    Tle4 Tele-Afflicted
    Warrington, Pa. USA
    I did drop the bass side a bit and it didnt seem to take care of it.
  4. kbold
    Lighter gauge E and A strings may help.
    2HBStrat likes this.
  5. rickthescot
    rickthescot Tele-Holic
    Drop it more?
    NewKid and jrblue like this.
  6. Tle4
    Tle4 Tele-Afflicted
    Warrington, Pa. USA
    I think the bass side is pretty low. Its not that it is louder than other strings. it just seems bass heavy on the low strings when I use drive or and overdriven amp. I guess Ill try lowering the whole pickup down lower and see if it tightens up the bass some more
  7. beninma
    beninma Friend of Leo's
    Massachusetts
    Is the action set up with the bass strings too low relative to the treble? That and pickup heights are the main things to work on.
    If you don’t hear it on clean sounds and do on overdriven sounds it’s not the guitar necessarily.
    What amp? What pedals if any? This is why a lot of us like pedals like tube screamers that roll off bass.
  8. rangercaster
    portland, or
    What amp ??? How are your controls set ???
  9. Tle4
    Tle4 Tele-Afflicted
    Warrington, Pa. USA
    I am using a Kemper with many different profiles (Mostly Fender model amps) but they all sound fine with my 52 Hot Rod Tele. The bass is tight with that guitar and much bassier with the American Standard with the CS Broadcaster pickup.
  10. Lef T
    Lef T Tele-Holic
    Ontario Canada
    I've got the same setup and have no problems with it.
    I've played it through various amps and it's all good.
    Sorry I can't help with an answer,except maybe setting up profiles for that guitar where you have an eq attenuation on the offending frequencies.
    NewKid likes this.
  11. Tle4
    Tle4 Tele-Afflicted
    Warrington, Pa. USA
    Yea I can do that but I was wanting to maybe get it closer to the same sound my 52 Hot Rod gets. Though i believe that is a hotter bridge pickup and they use 350k pots. I am wondering if I replace the volume pot with a 350k pot if it will tighten it up some more to get them closer to the same sound
  12. Skydog1010
    Skydog1010 Tele-Afflicted Platinum Supporter
    North Carolina
    500k pots might help and then you can raise bass side a smidge.
  13. jrblue
    jrblue Tele-Afflicted
    Santa Barbara
    Hard to believe it's just the guitar, because that kind of problem is not common with those pickups. There are many things it could be, and many remedies. I find that pot and cap values can be more significant in base tone than pickups (unless those are an extreme model). Do you have treble bleed? I'd start with that and maybe changing pot values before I did any worrying. I assume your strings aren't dead.
    schmee likes this.
  14. Tle4
    Tle4 Tele-Afflicted
    Warrington, Pa. USA
    I got the guitar used in a trade. The strings are good. I guess maybe I need to at least take the control plate off and take a look to see if anything was changed from stock.... Also this guitar has the tone pot that I think bypasses the pot when it is opened all the way. It locks in when it is all the way open. I would think it woudld be very bright when it is opened all the way
  15. matt117
    matt117 Tele-Holic
    Manitoba
    I’d check out the nut, if the string is getting choked out there and needs widening. check action height, I personally go for 4-5/64 at the 12th fret on the bass E string.
    hows the relief at 8th-9th fret area?
    And as others have said the pickup height itself.
    Measure it and your 52s pickups and compare.
  16. SPUDCASTER
    Grangeville, Idaho
    Does the pickup suit you without the OD on?
    Maybe try something like a Boss GE-7 graphic equalizer. Kick it on and roll off some bass frequencies when your OD is on. There are probably others too. Maybe less expensive for an experiment.
    The downside is you'll have two pedals to contend with when you're in OD mode.
    Just a suggestion. Hope you can adjust things without another piece of gear.
    Fretting out likes this.
  17. Tle4
    Tle4 Tele-Afflicted
    Warrington, Pa. USA
    I started doing a setup on it but didnt vheck the string height or relief yet. They seemed fine and the tele plays nice with no fret buzz. Action felt good. Guess I will give it a proper setup when I can find the time. The pickup height is about the same as my Hot Rod.
  18. Tle4
    Tle4 Tele-Afflicted
    Warrington, Pa. USA
    Without the OD on or an overdriven amp sound it is less noticable playing chords . Overdriven the low strings are fine for single note stuff but but kinda boomy and not tight and defined for power chord stuff on the low strings
    My Kemper has EQ's I can add before or after the preamp or I can EQ the whole output section after the amp that goes out to the speaker. I could also find amp profiles that work better with this guitar but it just seems there are much more lows with this guitar vs my Hot Rod. I guess if I have to I can just add an eq to the profiles I use and turn it on when I use this tele
  19. NewKid
    NewKid Tele-Holic
    Seattle
    Do you mean turn the bass down? I love how you put it. Is this how you talk normally? I love it!
  20. BCblues55
    BCblues55 Tele-Meister Gold Supporter
    Charlottesville, Virginia
    I’ve used a .047 capacitor in series on the pickup lead, and that cuts muddiness a lot. Perhaps it would also tame your E and A strings.
    Rowdyman and Mexitele Blues like this.
