Mike Simpson
Main amp is a Fender BFDR voiced 6v6 amp
Voiced ??
Voiced ??
I'm not about to suggest a brand as you have not mentioned budget.
My only preference is a Widerange style in the neck and a single coil in the bridge.
@ES 330 Have you looked at Guitar Fetish? They sell a Widerange type ( 9-10 Ohms) for $29.95 USD but you need a quickplug to install, or, look on Ebay. There are lots of Bridge single coils out there also. Just trying to help. I'd rather have a Widerange with all the wires and work it from there, but that's just me.
Wilde in the bridge would be good or a Tonerider Hot Classic which is up there in resistance and output. See Tonerider.com for a staggered bridge. I just put one in one of my Teles and am very impressed with it. JMHO
I run a dimarzio tone zone t in my mahogany thinline and its FAT, I also run 500k pots, treble bleed and series/split/parallel switch it can twang and rock heavy.
I would recommend Seymour Duncan Antiquities or Vintage and Antiquity,Broadcaster, Nocaster or maybe Jerry Donahue in the bridge.
Electrical tape some foam around the pickup sides and bottom under the top of the guitar if you can or just stuff some foam under the pickups and that will stop the squeal.Cav Huge Bridge and Seth Lover neck.
Squeal only appeared when drive pedal engaged. Perhaps
there was no to little block. I have since moved this project
to a solid body tele. I may switch this project with a Nashv
I have.
They only make it as a bridge pickup, I use the gfs fatbody in the neck(one of the best tele neck pups), actually if you don't mind SC vs HB the gfs fatbody 10k is a great hot tele pup at a great price I had that in my thin line prior. My top "rockin" tele bridge pup is the duncan bg-1400 the tz tele is close but the bg-1400 takes the cake. I have one in a classic vibe and it's a monster. Also I have to recommend wilde or older Bill Lawrence pickups, I have a modern player deluxe thin line that just never sounded good no matter what pickups I put in it, I had a set of vintage l550 and l560 sitting around for years so I popped them in, I already had 500k vols, series/parallel switches, tbx tone controls and treble bleed from the last set. Those pickups turned that guitar into the Holy grail of tele's, they are crystal clear,fat,hot yet clean up perfectly I measured them and they are about the same as a l500xl and l500l in ohms and henries but in a p90 package. That guitar sounds better than any of my 5 Les pauls, I have ordered some L90's to try in a Les paul because of this. BTW if anyone has any l550 or l560 pickups (not BL USA) please contact me.Is the Tone Zone T in your bridge or neck ??
Is it in both positions ??
