Pickup replacement
Discussion in 'Just Pickups' started by Vfc13, Jan 19, 2020.
  1. Vfc13
    Vfc13 Tele-Meister
    Nevada
    3392B191-2299-484F-8199-492B56255770.jpeg Hello all.. I just replaced the bridge pickup in my Indio T type...I soldiered the new one in exactly like the stock one was .i have no sound from the new one. Looking at the soldering job it looks ok but I did see a blob behind the switch lug..could this be shorting to the switch body? Here is a pic it’s the yellow wire.thanks in advance
  2. archiemax
    archiemax Tele-Meister
    Phoenix AZ
    What I'd do: Get a multi-meter, set it to "ohms" so you're using it as a continuity measurement. Set p/u switch to bridge position and plug in a working cable. Measure between tip and shaft. No resistance means you've grounded the hot lead. "Open" means there's no connection between the hot lead and the switch, or the pickup's shield and the ground. The reading you should get is the pickup's impedance.
    CFFF likes this.
  3. rigatele
    rigatele Tele-Afflicted
    ...when the volume pot is set to 10.
    CFFF likes this.
