Pickup position relative to saddles
Discussion in 'Tele-Technical' started by bancika, Mar 4, 2015.
  1. bancika
    bancika TDPRI Member
    Serbia
    Hi,
    could someone owning a tele with a 6 saddle bridge help? I'm trying to figure out distance between the intonation point on high E string and the bridge pickup, like this.
    I think it should be 1", give or take, but it would be awesome if someone could confirm.
    Thanks,
    Bane
  2. flyswatter
    flyswatter Friend of Leo's
    The intonation point should be determined by the intonation at the 12th fret -- i.e. open/ fretted/ harmonic E all in tune with one another.
    Any measurement based in distance between saddle and pickup is basically arbitrary if the intonation isn't otherwise correct.
  3. soulman969
    Englewood, CO
    Yeah, I too have to ask why that would be important to know. It's not how correct intonation is determined.
  4. NewPort
    NewPort Tele-Meister
    Nye Beach, Oregon
    I find it interesting, though this measurement has nothing to do with proper setting of intonation. My partscaster with a fairly standard neck measures 1", give or take.
    My partscaster with a 24" scale neck with 22 frets required a lot of modification to it's heel to create an overhang, so it would intonate, has a measurement of 9/16". Much closer and much more twangy even though it has the same bridge pickup as the other.
  5. bancika
    Serbia
    It's a weird question, I must admit...but it has nothing to do with intonation, bear with me for a moment :)
    I'm building a tele-like guitar without a tele bridge and trying to determine pickup placement that would be close to that of a real thing. High E intonation point should be the closest to 25.5" from the nut. It would be more precise to measure from one of the frets though. If someone is willing to do that, it would be even better :rolleyes:
    The PDF plan I used as a reference somehow shows pickup around .8" from the high E saddle. I tried to confirm that with a couple of photos of real guitars and drawings of tele bridges, and it always comes up around 1" (+-5%).
  6. Tele Jr
    Tele Jr Tele-Holic
    Minneapolis, MN
    Heads up most issues with a 6 saddle like that have to do with the low E string not having enough travel room. Many will cut the spring short to let it screw farther in.
  7. BryMelvin
    BryMelvin Friend of Leo's
    Arivaca AZ
    It varies: different models are different even with atypical pickups in a tele.
    Look at the difference say from a modern player to a tele stardard hh. Other things make the bridge placement different on a tele body. In the case of the modern player it's because it has a 22 fret neck with no overhang.
    Pickup distance from the bridge is not really critical, however the closer it is to the bridge the brighter ( or more shrill for some ) its tone will be.
  8. bancika
    Serbia
    looks like the biggest difference is between vintage and modern style bridge
  9. Vizcaster
    Glen Head, NY
    Bancica is correct - the pickup rout is in a different place relative to the string-through holes on an Am Std bridge compared to a vintage style bridge plate.
  10. LutherBurger
    LutherBurger Poster Extraordinaire
    NYC
    I'm curious... is the (single-coil) bridge pickup rout the same distance from the neck pocket on all Fender and Squier models?
  11. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    Yes, give or take a little bit as patterns changed over the years.
  12. LutherBurger
    NYC
    Thank you.
