Pickup options and opinions?
Discussion in 'Just Pickups' started by dekline24, Feb 17, 2017.
  1. dekline24
    dekline24 TDPRI Member
    New Hampshire
    Was thinking about putting a SD Jerry Donahue in the bridge of a ClassicVibe BSB. Would a SD Seth Lover pair well in the neck? What pots & caps should I use to balance everything?
  2. ZZB3
    ZZB3 Tele-Holic
    Salem, Oregon
    Yes it works well. I have an Antiquity neck with the JD in bridge. For this guitar 500k pots work better but it sounded fine with 250k as well.
  3. dekline24
    New Hampshire
    Thanks for the advice!
  4. Tony Done
    Tony Done Friend of Leo's
    Toowoomba, Australia
    I would go with 500K pots. The Seth Lover is two-wire, which means that you won't have the option of single or parallel switching should you ever decide you would like it.
    dekline24 likes this.
  5. SPUDCASTER
    Grangeville, Idaho
    For a "vintage" style bucker from SD with a 4 wire conductor.
    Look at the Alnico II Pro.
  6. Outcaster
    Outcaster Tele-Holic
    The Mountains of Western North Carolina
    SD will make you a 4 wire seth lover if thats what you want (i would) you have to order it from them that way. Get short legs as well
