Pickup magnet strength
Discussion in 'Tele-Technical' started by Pedalhead2, Nov 27, 2020.
  1. Pedalhead2
    Pedalhead2 NEW MEMBER!
    Connecticut
    Hello All,
    First time post here. I have a question for any of the more physics minded people.
    Question: Do hotter pickups have a stronger magnetic pull on the strings?
    Background of the question: I have what used to be a Squier Tele that has become a partscaster/teach myself guitar mechanics. I recently swapped out the stock bridge and a SD hot rail for a Wilkinson bridge and SD vintage broadcaster. In doing so, I took the SD quarter pounder neck and dropped the height significantly to accommodate the output balance. These changes effected my sustain considerably for the better. Prior to the changes, I had ordered a SD vintage tele neck expecting to want to not like the quarter pounder anymore. But my concern is that using lower output neck pickup and raising it will reduce all this beautiful sustain I have found. Or is that sustain all in the bridge?
    Thanks for any thoughts?
  2. glenlivet
    glenlivet Tele-Afflicted
    Marco.......Polo......
  3. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    >stronger magnetic pull on the strings>
    Sustain.
    Physics 101
    Take a SINGLE ball swinging pendulum deals and get it going, now place a magnet under it and see how long the ball swings.
    Bigger magnet, stop ball faster- strings like ball.
  4. Pedalhead2
    Connecticut
    Thanks so much. Section 2.8 was perfect.
  5. dan40
    dan40 Friend of Leo's
    Richmond Va
    A pickup with a hotter wind may not necessarily have a stronger magnet. Some higher output pickups use alnico magnets in their design and others will utilize a ceramic magnet. There are 4-5 grades of alnico magnets used in pickups and each type has a different gauss level. Ceramic magnets are also used in everything from cheap low budget pickups to high output pickups. You can use a gauss meter to determine if one pickup has a stronger magnet than another pickup but most of the time you can check the specs on the pickup manufacturers website.
    Pedalhead2 and Alex_C like this.
  6. Alex_C
    Alex_C Tele-Meister
    Hotter pickups have more windings, which wouldn't effect the magnetic pull. The magnet strength varies by model and manufacturer.
    dan40 and Pedalhead2 like this.
