Pickup Location for Dual Filtertron Cabronita?
Discussion in 'Tele Home Depot' started by poorman, Aug 1, 2011.
  1. poorman
    poorman TDPRI Member
    San Dimas
    I had another post asking for plans...got no response so I'll ask a slightly different question....
    I'm building a Cabronita style guitar from scratch and need to determine the pickup locations. Are there any resources, measurement or can anyone provide a plan?
    Thanks,
    Dave
  2. Ragtime Dan
    Ragtime Dan Tele-Holic Ad Free Member
    Fullerton, CA Birthplace
    I would just take the standard tele blueprint and overlay your Cabronita pickup routes?
  3. poorman
    San Dimas
    Yeah, but a couple mm one way or the other could have a significant tonal impact. I'm hoping for something more precise.
    There are several Cabronita builds on this forum...hopefully some of the builders will chime in.
  4. Bulldog87
    Bulldog87 Tele-Afflicted
    Louisiana, USA
    I'm definitely interested in knowing the bridge pickup distance from the bridge! :) I have a filtertron that is waiting for me to have the time to start building!!!
    So bump for poorman
  5. davmac
    davmac Tele-Afflicted
    Wirral, UK
    You could download the free evaluation copy of BigPrint. This allows you to load in a picture, specify one known dimension (such as the scale length) and then measure off any other dimension.
  6. Ragtime Dan
    Yes, that's the theory. But Even though George Fullerton, may have made drawings for Leo, with specs to the third decimal place. At Fender's factory, they all came out slightly different. So you have a bridge with a wide range of adjustment to compensate. In other words, don't let fretting about the exact position of the magnet pole pieces, stop you from proceeding with your project.
    Slightly different positions can sometimes produce a discernible difference in tone. But it's a subjective difference, not a do or die difference.
  7. jrcorp
    jrcorp TDPRI Member
    Coventry, RI
    Cool idea for a program, not surprised but impressed someone came up with this. A little OT, but I'll have to keep this in mind in the future if it could be of use.
  8. Ragtime Dan
    Here's an idea I stole from another thread ;)
    Go to the TV Jones website and look for the "TV Savalas Bridge Plate".
    It is a Telecaster bridge plate for Filtrons.
    The dimensions they show for the bridge plate, will let you figure out the position of the pickup, relative to standard four screw bridge mounting holes.
    They show the edge of the pickup hole at 1.25" from the four mounting screws centerline.
    Add .695" and that places the centerline of the pickup at 1.945"
    from the centerline of the four mounting screws.
  9. TheRumRunner
    TheRumRunner Tele-Afflicted
    TheGreatWhiteNorth
    Per Ragtime_Dan
    DW
  10. poorman
    San Dimas
    Now we're getting some good info! Thanks, gents.
  11. Ragtime Dan
    Yes Rum Runner. But you are showing the the "Modern Tele Bridge Plate" with the three screw layout. I am speaking of the TV Savalas Bridge Plate with four screws, which will correlate to the four screw mounting position shown on the Terry Downs drawing for reference.
  12. poorman
    San Dimas
    https://tvjones.com/cgi-bin/commerce.cgi?preadd=action&key=02-011-0100
    :D
  13. Ragtime Dan
    Yes That's it!
  14. Casual_Reader
    Casual_Reader Tele-Holic
    Ohio
    I haven't measured one or seen a Fender PDF of it (much less seen or held a CS one), but there are some consistencies in other Fender layouts... see page 5 of this: http://www.tdpri.com/forum/attachme...able-guitar-template-pdf-72-custom-deluxe-pdf
    the center lines in question would be the ones used for the WRHBs, 2 HB and P90 teles (the exceptions are noted on that page). Those lines are 1.238" and 5.482" from the inside edge of the neck route. That puts the center line of the bridge p'up at 1.888" from vintage bridge screw holes.
    again, it's not concrete, but that would be my best guess. Maybe someone will chime in with actual measurements.
  15. demillso
    demillso TDPRI Member
    Illinois
    I don't have the measurements here with me but I dropped a few images into Microstation and I believe the distance was almost exactly 2 inches from the 25.5 scale length line I used to line up the bridge to the centerline of the bridge pickup. (I didn't use a standard bridge so the mounting holes were no good to measure from)
