Pickup Height - Critical or Subjective
Discussion in 'Just Pickups' started by DugT, Oct 27, 2021.
How critical is pickup height?
  1. Very
    58.2%
  2. Somewhat
    30.4%
  3. Anywhere within 2 or 3mm of too high is good enough. Just don't set them too high.
    11.4%
  1. 3fngrs
    3fngrs Friend of Leo's
    Ohio
    I've had guitars that were set up by "pros" that sounded muddy because the pups were so close to the strings. Sounded much better when I backed them off. I almost always play with at least some dirt and, for me, I don't like the pups too high, especially humbuckers.
    That said, I haven't really figured out where I like the pups in my Telecaster. I should mess with them some more tonight. I'm going to jam again this weekend and I didn't like my sound last time.
    Peegoo likes this.
  2. naveed211
    naveed211 Friend of Leo's
    Iowa
    It’s critical because it does make a big difference in tone.
    But not so critical you need to obsess over it and adjust a dozen times until it’s perfect.
    Rule of thumb, start really low.
    Telecastoff1 likes this.
  3. Wallaby
    Wallaby Friend of Leo's
    Here
    I'm going with critical.
    Obsessed likes this.
  4. Armo
    Armo Tele-Holic
    Wales
    There are screws provided to adjust the height so I think that might be a clue.
    Happy Enchilada likes this.
  5. teletail
    teletail Friend of Leo's
    West By God Virginia
    PCollen, dang, Lone_Poor_Boy and 5 others like this.
  6. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    Just start fiddling with the adjustment screws and see what you think. You might find a very slight change makes a big difference or that only drastic changes make any difference at all. Everyone hears things differently, some hear what they want to hear.
    Personally after 40 odd years of electric guitar playing, I can't hear chit.
    Marc Morfei likes this.
  7. Peegoo
    Peegoo Doctor of Teleocity
    Challenging Definitions of Sin
    I didn't vote because 'critically subjective' wasn't a choice.
    rand z, aging_rocker and Recce like this.
  8. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    Pickup height is critical and you should definitely stress over it first before chasing other mods like Pots 'n Caps and Pickup swapping.
    Pause this video at 5seconds in and you can see how Hendrix has his pickups set:
    -neck: Flush with the bass side slightly under flush
    -middle: Slightly above the pickguard with bass side tipped highest
    -bridge: A little higher than the middle pickup but also with the bass side tipped higher
    There used to be another video that was very clear as the camera person focused on the picking end rather than the fretboard for most of the closeup shots of the performance but sadly that one was removed. There are other Hendrix videos out there too. He borrowed a lot of Strats but most of them showed he adjusted pickup heights away from 'standard', more often low to the body and tipped.
    If you have pickups with stronger magnets, like Squier ceramic, then they will sound better/the same as alnico if you lower them. Alnico is quite weak in comparison and when players set their ceramic pickup heights 'by the specs!' (which were made using alnico) they will certainly sound 'bad'. On the other end of player desires: Alnico has a hard time pushing amps like ceramic magnets can for metal.
    I have two humbucker guitars where I rotated the pickups 180deg, lowered and raised the screw poles, to get a much better beefier tone out of the guitars. One guitar I did several years ago and it's been my favorite player, a second guitar in the 'not bonding with it' I did the same mod to a little bit ago and it's become the favorite player too. They sound more like quiet P90s. So don't forget you can adjust screw poles like having a little EQ pedal.
    JohnnyCrash and Marc Morfei like this.
  9. Chiogtr4x
    Chiogtr4x Doctor of Teleocity Silver Supporter
    Manassas Park, VA
    I do think pickup height is both critical and subjective/very personal ( just like dirt boxes, strings, pick preferences)
    It's actually been years now since I had any setups/work done on any of my electrics,
    but I know that whenever I say, had setups done, or new pickups installed, which were always set to (ex.) Stew-Mac's, 'Gibson or Fender pickup height spec'- the sound was too loud or brash for me. ( played into a clean Fender amp, as reference)
    The tone never seemed warm- too powerful for me, and I would lower the height.
    I would start with getting the best bridge PU alone sound/ height that was pleasing to my ears, then adjust the neck pickup ( and if it had one middle) to be in balance with it.
    * and always angled- favoring treble side, lower on bass on any pickup
    Something like that!- I've just left everything alone for so long
  10. arlum
    arlum Tele-Afflicted Platinum Supporter
    O'Fallon, MO
    I think pickup height plays a real role in a guitars tone and volume as well as getting a balanced output across the six strings. I don't believe that one size fits all. I adjust them so everything sounds right to my ears.
  11. dreamingtele
    dreamingtele Friend of Leo's
    Melbourne, Australia
    When I first came to TDPRI, people here told me adjust pickup heights.
    i was like HUH? Crazy people, what do you mean by setting it low will make it sound nicer or high makes it a bit louder and punchy?
    when I did it, and heard the difference, i became one of those crazy people.
    now i cant stop adjusting pickups until i hear what I like to hear. Never replaced stock pickups again after this.
    guitfiddles, Marc Morfei and uriah1 like this.
  12. rand z
    rand z Friend of Leo's
    trumansburg, ny
    Yes.
    nixdad likes this.
  13. Weazel
    Weazel Tele-Holic
    Location Location
    ...and when the drummer kicks in....
    Tele-friend likes this.
  14. Peegoo
    Remember that the amp matters too. If you gig or usually play with the amp dialed up loud, have your amp at gig level when adjusting the pickups. This really matters, especially if you use your guitar's volume and tone controls when playing.
  15. bblumentritt
    bblumentritt Friend of Leo's Gold Supporter
    Austin, Texas
    There is definitely a 'sweet spot'. Some guitars (start with an "S" and end with "caster") are famous for out-of-tune issues from having the pickups too close to the strings.
    Different pickups require different height.
    Pickup Height
  16. DekeDog
    DekeDog Tele-Afflicted
    Carolina
    I heard that the closer pickups are to the strings, the more you hear the pickups; the farther away, the more you hear the guitar. I suspect this is true, esp. with hollow bodied guitars.
    When you buy from Lindy Fralin, he is emphatic that individual poles are preset to their optimum position relative to each other. I was having difficulty seating a control plate on a Tele, so I called him and sent pictures. (The problem was that the Tele was not properly routed to handle the selector switch in the reverse control plate.) He saw the pictures and asked me if I had adjusted the B-string pole on the bridge pickup, which I had. He strongly recommended I put it back to its original height, which I immediately did.
    joealso likes this.
  17. schoolie
    schoolie Tele-Holic
    Portland, OR
    It makes a huge difference in tone...and intonation. Maybe even more than wood species.
    ricknbaker likes this.
  18. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    I like the Tele neck pickup especially to be low. I like the bass understated, and low sounds right for my playing style. But I don’t know whether a slight change up or down makes a difference.
    What might be useful would be some discussion how a change lower or higher affects the tone.
  19. DekeDog
    Carolina
    Obsessed and joealso like this.
  20. Matthias
    Matthias Friend of Leo's Gold Supporter
    Third rock from the Sun
    You can go so high it causes issues with the string sounding clearly and in pitch. Below that, it’s up to what you want to achieve. Most definitely a pick-up height adjustment can be a more dramatic difference than some pick-up swaps.
