Pick up rings
Discussion in 'Tele Home Depot' started by Laren, Aug 19, 2020.
  1. Laren
    Laren Tele-Meister
    West Somerset
    Hi. all,
    I seem to be missing something. Where can I Find (UK) flat humbucker rings? I Mean flat bottom and top not angled. Do they have a specific name? All the ones I've found seem to be thicker one side than the other.
    Thanks in advance.
  2. wabashslim
    wabashslim Friend of Leo's
    Sonorous Desert
    Stewmac. Not UK, but...
  3. Splodgeness
    Splodgeness Tele-Meister
    Coventry, England
  4. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    If you can't find any locally and you have the slanted type in your parts bin, you can place it right-side-up on a piece of 220-grit sandpaper and work it back and forth to make the bottom flat with the top.
  5. Laren
    Laren Tele-Meister
    West Somerset
    Got some flat ones but mounting holes are different dimensions. Jesus. Sand paper it is. You live and learn.
    Thanks guys
    Toadtele and Peegoo like this.
  6. radiocaster
    europe
  7. Ripthorn
    Ripthorn Friend of Leo's
    Austin, TX
  8. radiocaster
    europe
  9. Chuckboy
    Chuckboy Tele-Meister
    Jeddo
    google FatBoyGuitars (uk) ... Montreaux now I think?
  10. Freeman Keller
    Humbuckers are commonly used on carved topped guitars which require a different ring for the bridge and neck and they need to be angled so the tops of the pups are level with the strings. As others have mentioned, flat rings are available or just hit the bottom of an angled ring on a belt sander.
    With that said I frequently use the wood rings that are available from LMII and other sources (including a forumite). I like to match the wood with other bits of trim - somehow plastic just looks like, er, plastic.
