Phaser Before or After Drive
Discussion in 'The Stomp Box' started by Kayle McGuire, Feb 24, 2018.
  1. Kayle McGuire
    Kayle McGuire Tele-Meister
    Hey guys,
    I can’t seem to figure out which I like better — my phaser early in my signal chain (before the drive) or later in the signal chain (after the drive).
    I’m going to keep moving it around the signal path until I find I place where I really like it.
    But where do you put your phaser in the signal chain?
  2. the tool
    the tool Tele-Holic
    Sweden
    I like it before drive. But i only use medium gain overdrive, almost clean. On distortion i dont use phaser at all. I rather use chorus on distortion wich i like after distorion. But the flanging or univibe type of effect i much like before distortion strangely... wich is odd.
    Bahhh... its all taste. Sometimes my head feels like my butt and sometimes the otherway around when i dable around with my pedals. :D
  3. Beatbx
    Beatbx Tele-Meister
    Eugene, OR
    I like having both set up. Sometimes one works better than the other.
    kuvash likes this.
  4. Mr.Ike
    Mr.Ike Tele-Meister
    Albany,NY
    I tried both and like mine after. It’s personal.
    Kayle McGuire and rich815 like this.
  5. Ebidis
    Ebidis Tele-Afflicted
    Alabama
    I like it before generally, but after can be cool depending on the sound you want at the moment.
  6. Shango66
    Shango66 Friend of Leo's
    For the best of both, I go drive/dirt at the front of my chain, then all the other stuff and finally a boost pedal. That way you have a balance of drive before and after.
  7. Suproman
    Suproman Tele-Holic
    Ottawa, ON, Canada
    I place mine between 2 drive pedals.
    con brio likes this.
  8. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    I use it after
  9. e44crowe
    e44crowe Tele-Meister
    Alabama
    I place mine 1st in the chain (technically 2nd after the tuner). Seems to work better with dirt if the phase sweeps into the OD. Like cool peaks in the gain.
  10. Bob Womack
    Bob Womack Tele-Afflicted
    Between Clever and Stupid
    I come from the generation that heard phasers, flangers, and delays on records and ran out and bought one and then discovered that on the records they did the phasing and flanging in the studio after the amp (distortion) and speaker. We learned the hard way because we couldn't make our pre-amplifier effects sound anything like the records.
    Bob
    Hollandcaster and telemnemonics like this.
  11. middy
    middy Friend of Leo's
    MSP
    Before
  12. artdecade
    artdecade Poster Extraordinaire
    Boggo Road
    Both sound pretty different. Which do you prefer?
  13. bigben55
    bigben55 Friend of Leo's
    Cincinnati, OH
    Before
  14. Vespa_One
    Vespa_One Tele-Holic
    US
    surprised to see so many people like it BEFORE....
    I hear tons of people say after. It is a modulation? and modulations often go after dirt...?
    The correct answer is to try both ways. This should have been a poll. Now to rip my board apart again and try every possible order.
    I've had it after but I'm off to experiment. I have a new envelope filter I need to work into the equation as well. Let the games begin.
  15. radiocaster
    europe
    I like after distortion for slow jet or medium speed, I like before with fast or medium speeds for Univibe type sounds.
    Sorry, I can't decide for you which one you like better.
  16. middy
    MSP
    Time-based modulation should go after (chorus / flanger). A phaser is not time-based modulation, it is phase-based and works well in either position.
  17. gtrguru
    gtrguru Friend of Leo's
    Detroit Metro
    Before
  18. Paul in Colorado
    R.I.P. 2019
    Mine is after dirt, before chorus or delay. YMMV and all.
  19. EddieLocrian
    EddieLocrian Tele-Afflicted
    Isle-of-Wight
    Hendrix = Before.
    Puzzle solved.
    Anode100 and E5RSY like this.
  20. telemnemonics
    After unless the amp is also distorted which it usually is if I run an OD pedal because it's seldom at unity gain.
    So, in between.
    Anybody put it in the loop of a distorted amp?
