Phase reverser circuit - have you tried this simple P.I. ?
Discussion in 'Amp Tech Center' started by Bendyha, Sep 10, 2019.
  1. Bendyha
    Bendyha Friend of Leo's Silver Supporter
    Northern Germany
    I can't recall ever seeing this PI in a guitar amp. I found this in a 1958 tech. sheet. Compared to a long tailed pair, it has about twice the gain, and about twice the THD, which is probably the reason it doesn't seem to turn up in HIFI amps, but since when has a bit of distortion ever worried us guitar amp builders. Does anyone have any experience with this circuit, or know where I can find examples of it either used or written up anywhere.
  2. TequilaCaster
    TequilaCaster Tele-Holic
    Between Time and Space
    Does not the old Supro Thunderbolt use this PI scheme?
  3. LetItGrowTone
    LetItGrowTone Tele-Meister
    U.S.
    With small differences, Ampeg B-15 and V4.
    Principle of operation, with a small variation on your circuit at the end of the page: http://www.valvewizard.co.uk/paraphase.html
    He says: "if the power valves are fixed biased then the paraphase will needs its own coupling cap and grid leak from the junction of Rf and R1". For an example see V4.
  4. wabashslim
    wabashslim Tele-Afflicted
    Sonorous Desert
    Is that a switch that grounds out the signal from the upper V4? Why?
  5. TequilaCaster
    Yes, it acts as a 'STAND BY' switch, by shorting the signal to ground, so it does not drive the following tubes' grids.
  6. Bendyha
    Northern Germany
    Nope, that is just a standard paraphase. Quite a different kettle of fish.
  7. Bendyha
    Northern Germany
    Ah...Merlin....the "Floating Paraphase" thats more like it. Other than the occasional mention, one doesn't seem to find much written about it. Crowhurst as usual is a good source.
    I've never seen the gain and distortion levels listed, and compared to a LTP before.
    The B-15 schem I have is a different PI....So is the V4, which is just a Schmitt.
  8. danlad
    danlad Tele-Meister
    Here and there
    A floating paraphase is on my list.
    It took me a decade to get round to my first push pull amp so you don't want to wait for any experience from me to try it though!
    Bendyha likes this.
  9. Bendyha
    Northern Germany
    Looking around a bit further, there are a few different ways, or rather, subtle differences between, various circuits that get the moniker "Floating Paraphase".
    Some are just subtle changes of resistor values in an effort to better balance the output (or rather the input to second tube to match that of the first) , other changes make the circuit quite different; sort of like the difference between a true Schmitt PI, and the Fender LTP. It seems the range between floating, non-floating, and side-branch PI's, and thier derivatives can be quite fine before one becomes the other, or unique in its own right.
    Still seeking a guitar amp schematic with a simple floating paraphase....will have to make dig through my archives again, and gatherwhat I find together.
    The raw symmetrical simplicity of the circuit in the OP is what I find so appealing.
  10. LetItGrowTone
    U.S.
    This, from V4 1971.
    Same thing except the signal for the second tube is taken from *before* the coupling caps, and so it needs "its own coupling cap and grid leak from the junction of Rf and R1".
    And instead of 1M/1M the split is 820K/1M, for symmetry.
    Bendyha likes this.
  11. Bendyha
    Northern Germany
    Closer, and different from the Ampeg, is the 1954 Fender 5D8 wide panel/low power Twin, with its self-biasing/ floating PI. But the cathode resistor is not shared, so it is not quiet the same sort of floating topology as the OP, or the one Merlin shows. This was a short lived circuit at Fender, but highly regarded by many.
  12. timfred
    timfred Tele-Meister
    Northern CA
    Ampeg Reverberocket
    One feature or issue is that at the onset of clipping, often the first half of the triode clips asymmetrically while the second half clips symmetrically. Maybe that's a good sound to you, maybe not.
    Bendyha likes this.
