Phase inverter plate resistors
MrCoolGuy
Fort Worth, TX
This might be a dumb question, but...
Why do blackface Deluxe Reverb layouts
(AB763) show two 100k PI plate load resistors, but the schematics show 100k and 82K.
I know the AA763 used two 100k resistors... I think they were left on the layout when they made AB763. They also left the mid cap value.
My main question is why would they do that? Isn't the imbalance off 100K vs 82K
Needed?
King Fan
Salt Lake City
You mean these? Images with original markup by Rob Robinette...
King Fan
Salt Lake City
It was a change. The different resistors balance the output of the two sides of the PI.
Good answer. Ever struggle with version control on your computer? Think what it was like for folks doing ink-and-ruler tech drawings they had to send to a specialized print shop -- that were then produced in large runs. Fender was penny-wise about something as simple as outdated tube charts; their schemes and layouts are fairly rich with inconsistencies, not just from one to another, but even more so over time, and as compared to what they were actually building on the shop floor.
And before you decide they were unprofessional, compare Fender to Gibson, where names, model numbers, and schematics were changing 'everything everywhere and all at once.' :)
MrCoolGuy
Fort Worth, TX
Yes, I understand what you are all saying.
There were typo-type mistakes on layouts and schematics...
But I don't think this was a mistake... at least not at first. Didn't the AA763 actually use two 100K PI plate load resistors?
I know, @Paul G. , that the mismatch is necessary to balance the PI output. That is why I'm asking why all amps don't do this.
I know some other amps (i wish i could remember specifically) have matching PI plate load resistors... whether they are 82K, 100K, 220K... they match.
I guess my question is... do they need to be offset or not? Why do some amps have matching pairs?
(I know I'm not giving example schematics here... the people that can answer this question accurately know exactly what I'm talking about...)
Does it have something to do with the value of the Long-tail -pair tail resistor?
2L man
Finland
82k to 100k ratio is not "matched" but closest using standard resistors. HiFi builders forums are good places to read PI balancing.
Paul G.
Rhode Island
...And before you decide they were unprofessional, compare Fender to Gibson, where names, model numbers, and schematics were changing 'everything everywhere and all at once.' :)
Even early Ampeg amplifiers will have circuits that don't match any schematic. Amps with the same model designation, similar dates of manufacture, will vary. Changes were made on the fly, I guess.
King Fan
Salt Lake City
Mistake, maybe, but equally or more often, *design or build change.*
But you’re not asking about the Fender diagrams as such, but why LTP plate loads are unbalanced, and whether it matters? See the short, clear section here about ’Balance:’
schmee
I think it was a simple mistake. The BFDR layout appears to maybe be a whole new layout drawing as opposed to just up dated. Also many BF and Brown face amps have the proper 82k/100k setup shown.
The non Reverb Deluxe has the 82k/100k setup with no revision.
Even the prior Brown Deluxe has that setup.
But BOTH AA and AB revisions of the Deluxe Reverb have dual 100k resistors shown.
schmee
Please see the DR AB763 schematic and layout linked to in post #2.
Drawing date codes are both C-FD.
Both show 82k and 100k LTP anode load resistors.
That's interesting. Here's a version of the same C-FD showing 100k/100k! That version you posted has super clean legible lines etc on it, unlike nearly all the old Fender ones. I wonder if it's a more recent "re-draw"?
MrCoolGuy
Fort Worth, TX
Exactly. All the AA763 and AB763 layouts that show 82k on one side are obviously edited. The schematics, however, do show 82k / 100k.
I believe AA763's actually did come with 100k/100k...
Thank you, @King Fan .
Yeah, sounds like it doesn't matter too much . I know there are a lot of other variables to consider to have balanced PI output. I think I'll use a 250k pot on one side and hear the difference.
2L man
Finland
I thought it was 82 /100 because some imbalance in the PI is actually a good thing for harmonics etc when it comes to guitar amps.
Obviously out of standard resistor values 82k and 100k function better balanced than two 100k or two 82k.
With 100k a 90k make operation balanced better in "typical" LTPPI. I have sometimes installed parallel two 180k to a place of 82k.
I agree with you that push pull impalance can sound sweet because of increased 2nd and other even harmonics. Howevet there come a potential danger when impalance cause Output Ttransformer core Saturation when playing loud and long time. This increase current flow thru tubes and OT and when OT core saturate there begin to accumulate heat which eventually can destroy the OT. Occasional hard picked notes often not make any harm although OT is chosed just bit too small and saturate only briefly :)
New Posts
