RoscoeElegante
Hey, all. Hope this you well.
On my Martin D-15M, bought (very) used a few years ago, the B string:
-Slips flat almost randomly
-Doesn't want to tune well with the G string
-Has a faint, very tinny buzz when played open
Meanwhile, the G string:
-Holds tune well, but won't intonate well starting at the 4th fret. It too is a bit flat from there upward--enough to sour some chords pretty noticeably
Both strings are wound on their respective tuning pegs properly. This happens to new strings (once they've stretched out), old strings, all brands of string, etc. I use the same medium gauge on it that the prior owner had used, but don't recall if he'd mentioned any tuning/stability problems on it. I do remember that the guitar had these problems when I got it, but they seemed less pronounced then. Maybe because of a honeymoon period.
So is this a tuning key + nut problem re: the B string, and a nut problem re: the G string?
If so, is the solution just a new tuning key for the B string, plus a newly cut and installed nut?
Everything else seems fine. The bridge is solid, the sound is rich and crisp, etc.
I'd just bring it to our local luthier but that shop has changed owners and luthiers a lot recently, and I don't hear good things (yet, hopefully).
With the semester crashing to an end, I'll finally have time to get the gear running right....
Thanks for your advice.
