#pennypincher 5e3p 'X' -- first timer; amalgamated "kit"... DIY info
Discussion in 'Shock Brother's DIY Amps' started by ecoast, Mar 1, 2017.
  1. robrob
    United States
    Don't change the output transformer tap you are currently using when you install your impedance selector. If you are using the 8 ohm tap for NFB leave it connected to the 8 ohm tap, not the switch output. You don't want the NFB level to change when you move your speaker impedance switch.
    ecoast likes this.
  2. ecoast
    ecoast Tele-Holic
    NWNJ
    PROBLEM:
    amp has been fine; many hours of use at volume, then this morning was playing it at volume (with FB switch in 'quietest/cleanest' position, if it matters) and it blew fuse/stopped playing
    pulled all the tubes, turn amp on, light bulb limiter full on= short
    can one of you fellas give me a quick troubleshoot on what/where to test first???
  3. ecoast
    ecoast Tele-Holic
    NWNJ
    Oops.
    Bad solder joint...
    Just came back to update.
