Pedaltrain Jr. BRKT-1 mounting bracket
Discussion in 'The Stomp Box' started by straightface, Apr 14, 2016.
  1. straightface
    straightface Friend of Leo's
    MA
    I just picked up one of the discontinued PT-Jr's that uses the BRKT-1 bracket kit to mount the Pedal Power 2+. Only problem is these kits seem to be sold out everywhere. Anyone know if there is another kit I can use to mount it under the board besides velcro? The new Pedaltrain brackets apparently don't fit this model.
  2. straightface
    MA
    Really? I'm the only one to run into this problem?
  3. Alamo
    Alamo Doctor of Teleocity
    Berlin
  4. straightface
    MA
    Thanks for the tip. They don't deliver to US though. First place I've seen that still has them.
  5. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    You mean the old style PT's with the circular holes in the front? If so, PM me...
  6. straightface
    MA
    PM sent, thanks. Hopefully some good news?
  7. cacophony
    cacophony Tele-Meister
    Philippines
    For my power plant, I use the brackets from a motor controller laying around. I matched and marked the center with a sharpie. Punched a hole. Drilled a 2mm pilot hole. Enlarged it with a 3.8mm bit.
    IMG20190206170227.jpg IMG20190206170655.jpg IMG20190206170444.jpg IMG20190206170247.jpg IMG20190206170428.jpg IMG20190206171412.jpg
    Alamo likes this.
  8. cacophony
    Philippines
    I figured I had to raise the mounting holes to accommodate the 9VAC on the side. I sandwiched the silicon rubber that's included in the motor controller to keep the bracket from scratching the sidewalls of the Modtone. So far I'm happy with the results.
    IMG20190214182233.jpg IMG20190214182221.jpg IMG20190214174612.jpg IMG20190214174154.jpg IMG20190214174118.jpg IMG20190214182204.jpg
  9. Chunkocaster
    In space with Ziggy
    I have an old pedaltrain too but its the pro. I think the brackets might be the same for the jnr? You can still find accessories for them on fleabay.
