Pedals that are compatible with an expression pedal
Discussion in 'The Stomp Box' started by Cole LR, Jun 24, 2020.
  1. Cole LR
    Cole LR TDPRI Member
    California
    I’ve recently got an Moog ep3 expression pedal to use with my avalanche run and I’m now looking to get other pedals that I could use it with. I’m not looking for anything too expensive, no mooger foogers or anything like that, but some suggestions of a good overdrive or chorus/vibrato pedal with an ex pedal inputs would be much appreciated.
  2. W.L.Weller
    W.L.Weller Tele-Holic
    Queens
  3. Cole LR
    California
    Do you know of any that combine chorus and vibrato, or like a multi efffects modulation pedal with an ex jack
  4. Twang Deluxe
    Twang Deluxe Tele-Holic
    Kehl
    Marshall RG1
  5. radiocaster
    europe
    There were a couple of Boss auto-wahs and one delay, but you could also look for a used Zoom.
  6. FenderLover
    Minnesota
    Love the Moog EP-3. Much better than the Roland RV-5. Go visit Strymon. You might think they are expensive, but many of their pedals are 2-in-1. You might even find a deal. I think all theirs allow use with expression (I have four), and was the reason I got my EP-3's (I have two).
  7. beninma
    beninma Friend of Leo's
    Earth
    EHX Memory Boy, Deluxe Memory Boy or various Deluxe Memory Man models do this.
    The Expression pedal is pretty wacked on them. Change the delay time, rate, depth, mix/blend, whatever. You can absolutely use it to do chorus/vibrato with expression.
    They're very fun to play with the expression pedal but very challenging to do anything musical. The expression pedal on some of the EHX pedals allows you change parameters beyond what the knob is capable of. E.x. I think on the delay pedals it will let you set the delay to 2x what the knob will, which does very crazy things because you're pushing the analog delay way past normal.
    Not that these are cheap pedals but expression input + useful features + cheap don't really seem to go together all that often.
    I have a Moog Ep-3, I can confirm it works perfectly with the Memory Boy and the Deluxe Memory Man 1100-TT. I'd imagine it works fine with the rest of them.
    Maybe it's time to pull the EP-3 out and try to get creative.
  8. thechad
    thechad Tele-Meister
    Kamloops
    I have a boss phase-shifter (ph-3 I think) that has an expression Jack. It’s not a cheap pedal, and it can be a bit of a tone suck, but it gets some pretty crazy sounds and probably even crazier with the expression add on. I can’t comment from experience though.
    now you’ve got me thinking I should get an expression pedal to try :rolleyes:
  9. Festofish
    Festofish Tele-Holic Silver Supporter
    Grand Rapids, MI
    Fender Pinwheel is nice!
    Boss Delay, flange or phase are nice too.
  10. codamedia
    Western Canada
    Keep in mind that although an expression pedal is an extremely simple device... they can be wired in numerous different ways.
    Just because an expression pedal works with one effect, that doesn't mean it will work (properly) with the next one.
    In short.... once you figure out what you want, research whether or not it will work with your expression pedal before buying it!
  11. Rich_S
    Rich_S Friend of Leo's Gold Supporter
    Potsdam, NY
    I’ve been doing great things with a homemade expression pedal hooked up to my EHX Grand Canyon delay. Programming is a bit tricky, but almost any parameter can be controlled.
