Pedalboard power supply OTHER THAN Voodoo Lab PP2 Plus
Discussion in 'The Stomp Box' started by joel_ostrom, May 13, 2013.
  1. joel_ostrom
    joel_ostrom Tele-Afflicted
    Calgary, AB
    My small board has room for about 10-12 pedals, but the Voodoo Lab power supply only has 8 outlets. If I want to power the other pedals, I was wondering if there was an alternative power supply that I could seek out. The voodoo Lab Pedal Power 2 Plus is so expensive (like $250+).
    Anybody use other power supplies and found them satisfactory?
    *EDIT* My mistake, after doing some price checking i've found them to be substantially less that what I said. Most places between $169-179. Regardless, please give me your thoughts on some alternative power supplies. I'm still curious.
    Cheers!
  2. Nub
    Nub Friend of Leo's
    SoCal
    I used 1Spots for years (usually 2 per board), and never had any real problems. I recently changed over to PP2+ and ISO 5 power supplies, and am glad I did. Much easier to run the power cables, and my boards actually sound a little better/tighter (don't really know why, but they do).
    Btw, you can easily power 10-12 pedals with a PP2+. Most drives can be daisy chained together, as they don't draw much power, but delays & modulation usually get their own outlet. There's also a courtesy outlet on the PP2+, that you can plug another power supply into. If you shop around, you can find used ones for $100-$120.
  3. Kestrel
    Kestrel Tele-Afflicted
    On the planet where the alphabet starts with "Z"
    Like Nub said, even though the PP2+ had 8 outputs, it is possible to power more pedals if you daisy chain a few from one output (as long as the pedals you're daisy chaining don't require more juice than the maximum mA of the particular output). However, you may get some unwanted noise depending on the pedals you daisy chain, which is why I don't recommend it.
    I have a T-Rex Fuel Tank Chameleon on my Pedaltrain Jr which is okay, but the Voodoo Lab PP2+ is better, in my opinion. I've tried to daisy chain a few pedals with the Fuel Tank Chameleon, but I get a lot of unwanted noise from certain pedals, even when I isolate them to one output, so I use the Fuel Tank Chameleon for the pedals that draw a lot of juice and a 1 Spot for those that don't.
  4. jackal
    jackal Friend of Leo's Platinum Supporter
    mojave desert
    BBE Supra-Charger is the only other power supply than the Voodoo Lab that I'd consider, the one-spot style (tried several brands) always gave me noise and the pedals didn't sound as good. Just my experience.
  5. sagaci
    sagaci Tele-Meister
    Have you already got the 10-12 pedals? If so, what are they?
    It's hard to recommend a power supply when the pedal specifics are unknown. Even if that are all 9V low current, 12 pedals would call out for a larger than standard power supply solution. You could try a one spot but I'd be wary about non-isolation with that many pedals. You could go with two T-Rex fuel tank juniors but that would cost as much as a PP2+ though you'd have 10 outlets and they would be small and separate.
  6. dr. love
    dr. love Tele-Meister
    I just got one of the redesigned MXR Power Bricks and am satisfied so far. It's quiet in my rig and more than enough juice.
  7. joel_ostrom
    Calgary, AB
    I've never thought to daisy-chain pedals using the PP2. This might be a good (and cheaper) route to go until I eventually may need to purchase a 2nd one.
    All my pedals are standard 9V requirement type pedals.
    TC Electronics Polytune
    Wampler Analog Delay
    Xotic Effects SP Compressor
    Voodoo Lab Giggity
    Boss GE-7
    Fulltone OCD Overdrive
    MXR Clean Boost
    Boss CE-5 Chorus Ensemble
    Road Rage Dual Input/Output Buffer
    How do you go about chaining effects together if the pedal doesn't have a DC output on it? Just one of these?
  8. xtrajerry
    xtrajerry Doctor of Teleocity
    Lehigh Valley, PA
    No this one.. [​IMG]
  9. k tone
    k tone Tele-Afflicted
    I power 8 with my T-Rex Fuel Tank Jr.
  10. Dimitri92
    Dimitri92 TDPRI Member
    Amsterdam
    Carl Martin Power supply
  11. castpolymer
    castpolymer Poster Extraordinaire
    Edmond, Oklahoma
    I have two Dunlop Power bricks and they are great. 3 18v slots and 6 9v slots. Had mine for 3 - 4 years and they have never failed me yet.
  12. BWNadeau
    BWNadeau Tele-Afflicted
    Lachute, Canada
    I daisy chain the 8 pedals on my board off an ISO-5 - it comes down to chaining the ones that don't need as much juice, which requires some research and come trial and error.
  13. JHVH!
    JHVH! Banned
    east
  14. lefty73
    lefty73 Tele-Afflicted
    Another vote for BBE's Supa Charger here. It's cheaper (or was cheaper) than the Voodoo Lab, it easily powers the pedals that need different voltages in my forum signature, the leads are long to accommodate just about any placement of pedals on most boards, and it's beer proof. Not sure if BBE can verify the last one, but I did spill a Corona on mine on Cinco de Mayo and it never missed a beat.
  15. tekbow
    tekbow Tele-Afflicted
  16. Coldacre
    Coldacre Tele-Meister
    Nabootique
    you can pick up 2 Supa Chargers brand new for the sum of $180.
  17. ChipOnly
    ChipOnly Tele-Holic
    Champaign, IL
    I have several of these. Totally the way to go for powering more than 8 pedals off the PP2+ IMO, seems like hardly anyone realizes these exist.
  18. Zagnut
    Zagnut Tele-Meister
    Seattle
  19. JHVH!
    JHVH! Banned
    east
    I've noticed it too. I'll bet you actually read your manuals
    as well, don't you?
    Oh, and "meow".
