Peavey XR600B Repair
Discussion in 'Amp Tech Center' started by dkal24, Sep 24, 2020.
  1. dkal24
    dkal24 TDPRI Member
    Clifton, NJ
    Hello all.
    I have a Peavey amp that I can use if I can fix it. It had a blown fuse in it so I replaced it and powered it up. The hum was very loud without any speakers hooked up. I only kept the power on for a couple secs. The new fuse did not blow. I opened up the amp and everything looks fine inside.
    The amp is a 1982 model, schematic 400BH. Some output transistors are known to fail on these older amps, but I sure can use some input from you guys. Let me know what you think.
  2. rangercaster
    Knoxville TN for now
    It's not even 40 years old yet, so just a minor issue....
  3. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. UK.
    Check the output transistors first. There will be a few damaged but replace all of them to be on the safe side.
    Check the driver transistors.
    Wally and Bill Moore like this.
  4. dkal24
    dkal24 TDPRI Member
    Clifton, NJ
    YEA.... the weird thing is this amp crapped out 30 years ago. I just shoved it under a chair and bought another one. Also this amp was worked on after it left the Peavey factory. It has 3 different brands of output transistors installed....from what I read, all 8 should be the same brand.
  5. dkal24
    dkal24 TDPRI Member
    Clifton, NJ
    I'm about to pull all the output transistors but I'm not sure which one's are the drivers.
  6. Bill Moore
    Bill Moore Tele-Afflicted Silver Supporter
    Silver City, New Mexico
  7. Jon Snell
    Jurassic Coast. UK.
    The drivers have their emitters, connected to the base of the output transistors and 'drive' current into the bases which, in turn, drive current into your speaker load.
    Q2 drives Q3 that drives the output transistors.
    Check any resistor with the triangle next to it, R25 & R26 etc and if failed replace ONLY with the same fire proof type!
  8. dkal24
    dkal24 TDPRI Member
    Clifton, NJ
    Thx Jon
